Tall riders on a Salsa Cutthroat- Mtbr.com
Results 1 to 13 of 13
    Can an XL Salsa Cutthroat be setup so that the top of the saddle to center of BB is 83cm and the handlebars are level with the saddle?
    Thanks.
    Oct 2011
    Here's pic of my XL with the seat post adjusted for a saddle height of 82 cm and the stem flipped down with no spacers. Maybe that helps.
    IMG_3141 by jan nikolajsen, on Flickr
    Quote Originally Posted by jan_nikolajsen View Post
    Hi Jan,
    I previously read your thread about your build. Impressive!
    Are you saying that in the picture if you put a saddle on the seatpost, then the top of the saddle would be 82cm from the center of the BB? Do you think with the stem flipped up and 30mm of spacers under the stem(the max?) that the top of the bars would be level with the saddle?
    Oct 2011
    Quote Originally Posted by happyriding View Post
    Hi Jan,
    Thanks. Yes, the saddle would be at my height, 82cm, if it was mounted. It seems to me you could get quite close to the desired level with the bars - but when I purchased the frame the steerer was cut like this so no telling for sure.
    Reputation: Flushing Shadow's Avatar
    Apr 2019
    Thanks.
    Are you saying that you have 100cm+ inseam on shoes? because that's kinda tall
    Surly Big Dummy XT 2x9
    Salsa Fargo XT/Gevenalle 2x11
    Thanks Jan.
    Quote Originally Posted by Flushing Shadow View Post
    Maybe you could show us the calculations that produced your 100cm PBH (pubic bone height) measurement. My seat height is only 1cm higher than Jan's, and I can guarantee you that neither of us has a 100 cm PBH.
    Apr 2019
    Thanks Jan.
    Well, 83cm plus a 175mm crank is kinda like 100cm in my book? unless you have really thick soles on your shoes, that makes up for almost the same amount of inseam.
    You're ignoring the geometry of the ankle. Your heels would need to be centered over the pedal spindle for your inseam+crank length assumption to be valid. The ankle + foot length creates an offset, so that the resulting hypotenuse is longer than the inseam, about 9% longer, and that hypotenuse is the saddle-to-BB + crank length.
    Hence the age old rules of thumb for pedal-to-seat-top = 109% of inseam, or BB-to-seat-top is .883 of inseam.
    Use these numbers and you'll see that the riders above have 36"-ish inseams, which is fairly normal at 6'3" height.
    Apr 2019
    Ah, like that, but i run longer then normal cranks, does dat change the 109% rule?
    Since the 109% rule is based on pedal-to-seat distance, it considers crank length directly. The rule would apply the same even if you had 165mm cranks on one bike and 180mm on another.
    The 0.883 rule, on the other hand, is based on BB-to-seat, so it assumes a "standard" crank length, and therefore would be adjusted if using notably longer/shorter cranks.
    Apr 2019
    huh? if i base my distance in my inseam, say 93cm, then my 109% is 101,37cm, correct? When i go from 175 to 185mm cranks, like i did, there is no consideration for that, is there? or am i confused now?
    The 109 rule is based on the PEDAL-to-seat distance. PEDAL, not BB!!! So put the pedal at the bottom of its stroke, and measure to the top of the seat, along the axis of the seattube. That should be approx. 101cm as you computed. If you set the seat to 101cm with 175mm cranks, and then changed to 185, then that distance would now be 102cm, and you would need to lower your seat 1cm to maintain same pedal stroke.
    Apr 2019
    Got it!
  1. Salsa Cutthroat Tour Divide bike
    By fitz3641 in forum Salsa
    Last Post: 03-25-2020, 05:23 PM
  2. Dear Salsa: Please make a flat bar Cutthroat
    By markymark in forum Salsa
    Last Post: 01-31-2018, 04:36 PM
  3. Salsa Cutthroat
    By thesilversurfer in forum Bikepacking and Bike Expedition
    Last Post: 01-03-2018, 07:47 PM
  4. Warbird and cutthroat actual weight
    By Soihtu in forum Salsa
    Last Post: 09-11-2017, 04:29 AM
  5. Hi My Name's Cutthroat, and I'm Depressed....
    By cutthroat in forum Turner
    Last Post: 09-22-2005, 07:51 AM
Members who have read this thread: 7
