• 12-13-2016
    Raymo853
    Spearfish Single Pivots, Instructions to Service Pivots
    I want to service the pivots and replace the bearings on my single pivot Spearfish. (Mine is a 2013, blank ano, thu-axle) Does anyone know of a good instruction set for the replacement? I want something better than just the reverse of disassembly, hoping to find torque specs, what to grease, what to thread lock, ....
    I already have the kit and know what bearings to use: four 698-2RS (8x19x6 mm) and two 6900RS (10x22x6 mm)
    2013 Spearfish 1 Frame | Bikes | Salsa Cycles
    Pivot Kit Spearfish 2011?2013 | Parts & Accessories | Salsa Cycles
    Attachment 1110199
  • 12-15-2016
    Raymo853
    When I get back from Christmas travels, I plan to do this and write up basic intructions. Am going to email Salsa and see if they have info to share.
    Sent from my SM-G900V using Tapatalk
  • 12-16-2016
    MudInMyEars
    I was planning to do the same for my 2013 Spearfish after the new year. I am interested in your plans. Need to order parts first [emoji16]. I'll post up if I find any information.
  • 12-16-2016
    Raymo853
    I emailed Salsa. They sent me some basic advice plus a blueprint/diagram listing all the torque specs and surface prep recommendations. Generally for surface prep: grease bearings and the surgace they are pressed into, grease the shaft of pivots going through a bearing, and all threads get blue Loctite.
  • 12-16-2016
    Raymo853
    The diagram http://cloud.tapatalk.com/s/585432c1...orque-Spec.pdf
  • 01-22-2017
    Raymo853
    Just started the rebuild, finally. But I have run into a problem. One of the bolts in the rebuild kit is different. The upper/front shock mount was installed in the factory with a bolt with rounded outsides and flat insides. The new one has flat outsides and angled insides. I am emailing Salsa now to check if it is ok.
    Attachment 1117217
  • 01-24-2017
    Raymo853
    Just finished the rebuild and first test ride. It feels so much better, plan to write up the steps soon.
  • 01-24-2017
    Raymo853
    Did have to reuse the front shock mount bolt as my frame uses a bolt different than the kit had.
