Selma TI geometry- Mtbr.com
Results 1 to 2 of 2
    Selma TI geometry
    So, did the Selma geometry change going from steel to Ti? I see that the head tube angle is slacker by a degree, but everything else is the same...
    Any idea what would happen to these angles with an enabler fork and a fat front?
    Thanks,
    t
    if you look under the new el mar ti geo chart. it gives you the geo with both 468mm and 483mm axle to crown measurments. the enabler is the sorter version geo so yes, it will steepen the geo and drop the bb by 5mm. the new ti bikes are based on longer forks and the steel el mar i based closer to the shorter forks.
