Salsa SUL steel stem with H-Bars?- Mtbr.com
Results 1 to 24 of 24
    get down!
    Reputation: appleSSeed's Avatar
    yoski, I'm gonna get my frame in a few and need to get a stem asap
    what I want is the salsa stem or a custom steel stem but am worried about the ride with an h-bar
    setup will be with a rigid KM fork and 130mm x 10 or 15 rise
    I would go with a Thomson but I don't really like the way they look on steel frames since they're so big...I prefer the old time look of steel with steel...gay, I know *not that there's anything wrong with that
    I was thinking
    a) the steel would be a welcome flex with the rigid
    b) the SUL system of the salsa would prevent some flex
    c) a custom builder could make a stiff stem for use with them
    or should I say F' it and get the thomson? I do have a Thomson post
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Kill your... television
    Reputation: motoman711's Avatar
    Just make sure
    Make sure that the stem has a strong bar clamp. You want 4 bolts to keep the bar from twisting in the clamp. As far as flex goes: the bars have flex designed into them (if they are the Ti models) I can actually feel it on my rigid KM. Jeff flattens the 1 inch tubing at the ends to meet the 7/8" tubing of the cross bars. This acts as a flex point. I had an aluminium riser on my KM before this and my hands would bounce off the bar on choppy downhills. With the H-Bar it is much smoother.
    Moto
    get down!
    it's only a 2 bolt clamp on the salsa but maybe the SUL system would help, maybe it's just a gimmick...that's working?
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    2 bolts 4 bolts, does it REALLY matter? Personally I think its hype. I've never had a problem w/2 bolt stems, or 1 bolts stems for that matter. Much less 4 bolts. What about 3? will the odd number throw everything off? oh crap!
    Seriously though, I've got a SUL on my crosser, and it works fantastically well. My bras don't rotate. And that's what you want out of a stem, right?
    Just a regular guy.
    S.u.l.
    Quote Originally Posted by appleSSeed
    What is S.U.L. technology? Flip floppable clamp face or something like that? It really has to do with the clamp area. A 4 bolt clamp just holds the bar tighter. You don't want the bar rotating in the clamp when you land off a drop or jump. I know that Jeff recommends a 4-bolt clamp. And, he specifically mentions a Thomson.
    Moto
    hispanic mechanic
    Reputation: sslos's Avatar
    Maybe you're not gyrating enough...
    Quote Originally Posted by ~martini~
    Try more shoulder movement. That's what the gals at the strip bar do, anyway!
    the los
    Support your local trail organization.
    www.swimba.org
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    I like the Salsa SUL stems
    I was thinking
    Theyre a little porky but their stiffness makes up for it all. Im using one with a easton monkey XC and its da chit mang. Another thing to keep in mind is that alot of the stiffmness of the stem is due to its clamp size (welded area) which are pretty tall.
    get down!
    yeah I didn't think it would make a difference, I have a 2 bolt specialized stem on my cruiser with huge crusier bars and it's held up fine...I think I'll just go with the salsa.
    Wandering not Lost
    Reputation: BThor's Avatar
    I run an h-bar with the raceface stem (two bolt) although I do not have a problem with it I do seen the advantage of a 4 bolt stem such as the thomson. I can feel the flex of the stem when I am really on the ends of my h-bar.
    sidenote....I love the bar
    Depends on your riding style...
    If you don't go off any drops larger than a foot or so, a two bolt stem would work just fine. If you go bigger than that (and I do, with the same KM rigid fork) you will appreciate the feeling of having your bars stay in the same position with the 4 bolt stem. With the 2 bolt you can use the bar rotation as a form of suspension, but it gets hard to steer after the landing...personal experience.
    bike ON
    bob
    red-haze
    The more I know the more I know I don't know.
    Let the bike ride the trail, you ride the bike.
    Look where you want to go, not where you don't want to go.
    giddy up!
    Reputation: donkey's Avatar
    Steel salso stems have been discontinued. I'd look for one quick, as they're drying up.
    B
    www.thepathbikeshop.com
    get down!
    anyone know what the effective length of a 135mm x 15 rise would be as compared to 135mm x 10 or 120 x 15 vs. 120 x 10?
    how does rise affect reach?
    Oct 2002
    I am running my HBars on a Syntance F99
    Should I change it out?!
    However, it is only temporary while I wait... and wait... and wait... for something special.
    No Reputation!
    Reputation: Fastskiguy's Avatar
    # of bolts=probably does not matter.
    Now this study is on road stems but you've gotta assume it's the same as far as stiffness. Check out the whole freakin' thing at
    http://www.biketechreview.com/stems/index.htm
    Click "Results and Discussion" then the "Analysis and Summary" and read the "Stiffness" section.
    or if you just want the good stuff...
    "It should also be clear that bar bolt pattern has no material affect on stiffness.* For example, it is a common belief that a four bolt pattern will be stiffer than a one or two-bolt pattern.* The TTT Forgie lays this notion to bed.* The Forgie uses a two bolt pattern, yet has the highest stiffness measured.** Of course, the high stiffness of the Forgie is a function of the large diameter of the extension tube."
    It's pretty cool, they took all of these stems and really put the wood to 'em then charted everything-way more information that you wanted to know.
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    SOHCAHTOA can figure it out.
    get down!
    thanks for that!
    that was a great read although I wish they would have tested a steel stem that was welded as well.
    now, can anyone help me on my stem sizing question?
    I'm trying to duplicate a total cockpit length of 29.33070866 inches or 745.000001 mm (25 inch top tube with 110mm stem @ 6 degree rise)
    with my H-Bar and am having a hard time coming up with the right numbers I know it should be a 120 or 130 rise by 5 or 15 but don't know which combo
    get down!
    Quote Originally Posted by Nat
    haha, what's that
    giddy up!
    thanks for that!
    I don't think there is a hard and fast rule on a conversion from straight bars to an h-bar. On Jeff's site he recommends I think 20mm in length and maybe a bit of rise? I'd probably set it up with some crappy stems first to get your length and rise right, then worry about finding a salsa somewhere..
    FWIW, in my h-bar days, I went with a stem 15mm longer and 10 degrees higher.
    B
    Nat
    Nat is offline
    haha, what's that
    Remember your trigonometry? I'd do it for you, but I'm eating my lunch right now.
    thanks for that!
    I have 130mmX15 degree on mine, It works beautifully, I actually bought a $20 stem to try it out before hand. I like the higher position. I started with a 120mmX5 degree rise. The higher position allows me to get some weight off of the wrists (especially helpful with rigid)
    Nat
    Nat is offline
    thanks for that!
    Oh yeah, Jeff has that adjustable stem for rent, so you can dial in exactly which rise/reach feels best.
    Reputation: logbiter's Avatar
    coupla screen shots from an excel spreadsheet for ya on stem comparisons. pm me if'n you want it... I believe I got it from naestep/speeddub nate coupla years back. sorry if the credit goes to someone else.
    Serge
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    Iā€™m terrible at trig
    Sin, cosin, tangent to what
    But I can draw in CAD like a demon
    [IMG]
    From 0
    120 10 deg = 4 1/8”
    135 10 deg = 4 21/32”
    120 15 deg = 3 59/64”
    135 15 deg = 4 13/32”
    I went 20mm longer and 10 deg. Up from a flat Salsa bar to a Jones bar
    I am the owl
    Reputation: riderx's Avatar
    I've been running an SUL w/ the H-bars for over a year. Works great.
    SingleSpeedOutlaw .com
    Riding Bikes and Drinking Beer.
  1. Body Science of Handlebar "Sweep/Bend" ?
    By PiroChu in forum General Discussion
    Last Post: 09-08-2004, 07:03 PM
  2. quill-type stem questions
    By chuffer in forum Singlespeed
    Last Post: 04-29-2004, 06:17 AM
  3. So whats the BIG difference b/w Steel and Aluminum frames?!
    By Carlosantana in forum General Discussion
    Last Post: 04-22-2004, 02:50 PM
  4. Worth it?
    By crank in forum Tooltime
    Last Post: 03-29-2004, 10:14 PM
  5. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
