Salsa Fargo cable routing help- Mtbr.com
Results 1 to 5 of 5
    Nov 2007
    Building... what I believe is a large generation 2 (has replaceable hanger) but there are no downtime cable adjusters. Do I have to run a cable the entire way to the rear of the bike? And do I need a special front derail? That will accept a cable end? If anyone has any pics it would be greatly appreciated.
    Aaron Boatman
    Lake Havasu City
    Local Rides AZ stuff
    FACEBOOK
    Get some SRAM inline adjusters. If it is a Gen2 you won't be able to run cable from end to end unless you zip tie it on.
    I bought the jagwire pro kit (road if using drop levers) - it has a plastic sleeve that helps protect the cable from where it exits the stop on the down tube to where it connects further back on the bike.
    Nov 2007
    I don't have those down tube stops. Anyone know why?
    Aaron Boatman
    Lake Havasu City
    FACEBOOK
    Dec 2009
    Quote Originally Posted by stand-up-pride View Post
    So you must have the full housing guides on the underside of the top tube. You'll still need in-line barrel adjusters; I like the shimano ones, the jagwires wouldnt hold their adjustment on rough terrain. A problem solvers direct-mount front dérailleur adaptor and a SRAM direct mount dérailleur will work great for your front shifting.
    Nov 2007
    Sweet thanks for info on direct mount adapter. After some more Internet search I believe I have the ocean blue 2013 Fargo gen 3
  1. Salsa Fargo with 29+
    By NW Gravel Hunter in forum Salsa
    Last Post: 03-02-2014, 07:57 AM
  2. Who rides a Salsa Fargo ?
    By rickcin in forum 29er Bikes
    Last Post: 11-10-2012, 06:00 AM
  3. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  4. Salsa Fargo
    By LBIkid in forum Where are the Best Deals?
    Last Post: 08-25-2011, 12:36 PM
  5. Salsa Fargo
    By edsterra in forum Clydesdales/Tall Riders
    Last Post: 04-05-2011, 10:55 AM
