• 02-19-2015
    sgtrobo
    Is "rotor rub" under turning or hard pedaling common (Salsa Fargo)?
    So the bike:
    2012 Salsa Fargo (with road BB7s, 180/160mm F/R)
    me:
    *picture of 255# chubby former powerlifter*
    I hear a heavy rotor rub under the following circumstances:
    1. when I start to ride, I put my left foot on the left pedal and pedal once to get going, then swing my right foot over the bike. I hear heavy rotor rub until I'm centered on the bike, then it goes away.
    2. When I turn corners and lean into the corner, I'll hear some obvious rotor rub.
    3. when I stand and hammer. this agitates me because I go through a lot of heavy gravel on the way to work during my commute (well, I purposely go through the gravel, but dammit it's fun!) and it frequently requires some hammering to power through
    4. When I have done many miles or finished a climb, I will stand with pedals at 6 and 12 o'clock, alternating with my left foot at 6 o'clock, then my right foot at 6 o'clock, to stretch out all my stuff. Definite rotor rub
    I've tightened the QR as best as I can, taken many steps to ensure that the wheel is centered. I don't think anything is out of true because it doesn't make that noise when I'm NOT in those situations (i.e. just pedaling along in a straight line)
    now it seems that I'm causing an inordinate amount of wheel flex, or is it possibly something else causing this deliciously agitating noise?
  • 02-19-2015
    Harold
    Not wheel flex.
    Frame/fork flex (and more specifically, the interface between the frame and hub), depending on whether you're hearing it in the front or back.
    The Fargo is steel, which is known to be flexier than aluminum. That's why steel is more comfortable in a touring bike. You are a bigger guy, so you put more stress on the bike than a 140lb racer boy.
    This is also why thru axles are becoming more and more common. They stiffen the interface between the frame/fork and the hub.
    With a frame that's limited to QR type axles, there's really only one way you can stiffen those interfaces. Use hubs that allow for 9mm front and 10mm rear skewers like the DT RWS system, or convert them to bolt-on axles. If your hubs have swappable end caps to convert to thru-axle, there's a good chance that end caps are available that would allow you to use the beefier RWS skewers (standard skewers are 5mm in diameter, so much more flexy - and be aware, you can get RWS skewers in the 5mm flavor, too).
  • 02-19-2015
    sgtrobo
    well buggers.
    Why would a frame be limited to QR axles? Why isn't it possibly to use a thru-axle? Is it the shape of the dropouts or whatever? I only hear it from the front, BTW.
    I'm willing to get a new set of hubs if it means getting rid of this. I was prepared to buy a whole new wheelset to be honest.
    so I just found the DT RWS on the DT Swiss website. How can I tell if my hubs are compatible with this skewer type? Is it safe to assume that all DT Swiss hubs are compatible with this (i.e. the DT 350 or 240?) Is it a proprietary thing, or are other hubs compatible (XT hubs? Chris King? Hope? etc)
  • 02-19-2015
    TBarnaby
    I don't think that DT Swiss RWS is going to fix your issues. It's still just a QR. A though-axle is different in that it inserts through a circular hole on one side and then threads into the other side of the fork/frame. It's also a larger diameter.
  • 02-19-2015
    sgtrobo
    so a thru-axle is something that is frame-specific, not just hub-specific?
  • 02-19-2015
    HitmenOnlyInc
    I think this is a fork flex issue. Like I said in the other thread. You being a big guy is flexing the fork and making the rotor rub in certain instances. Like you said when you mount your bike from one pedal you hear the rub, you are flexing the fork on the side you are mounting from. Not a big deal IMO.
  • 02-19-2015
    Harold
    You'll have to look up the specifics for whatever hubs you have, to see if they have the option to use those skewers. Hubs other than DT are compatible (I have a Specialized hub that has an RWS front on it), but probably a little less common than DT's own stuff. My wife's mtb has DT Swiss Tricon wheels, and the hubs have end caps for the RWS skewers. they're beefy and pretty stiff. Not quite to the level of my new bike which has actual thru axles front and rear, but definitely better than 5mm skewers.
    For example:
    Pro 2 EVO Front Hub | Hope Tech | Made in Barnoldswick, England
    Under specs, it lists axle compatibility, so every axle spec they mention will have a different set of end caps available. Since this one is a front hub, we'd be looking for a 9mm axle. Like I said, any hub with swappable end caps for wide range of axle choices SHOULD have 9/10mm compatibility.
    As for why a frame would be limited to QR axles, the dropouts are shaped totally differently. QR axles have been around for a really long time and started their life on road bikes. Thru axles are a bit newer and actually thread directly into the frame/fork, and were designed for mtb's first (and now they're being adopted on cross and some road bikes, even). They also have to be removed completely to pull the wheel out, whereas a QR is just loosened and left in the hub.
  • 02-19-2015
    Harold
    It's true we can't know for sure if they will fix his issues. But it's the stiffest interface he can use on the bike he has.
    The quickest/simplest/cheapest thing to fix the problem would be to dial the brake pads out a little bit so the rotor has a little more room to move when the bike flexes. Or ignore it.
  • 02-19-2015
    bmike
    I weigh just a bit less than the OP, about the same loaded for backpacking. the DT Swiss RWS made a difference for me... its small, but it helps. Having someone check the tension in the wheel, and proper brake setup will help too.
    With BB7s there is just some noise that comes and goes that you can't get rid of, especially if you are running the BB7 road, and road levers. Just have to have things setup tight in order to get good feel on the lever. When I switched to a Jones bar and MTB lever and BB7 MT things improved quite a bit.
  • 02-19-2015
    sgtrobo
    so is the RWS just something I switch out with my QR skewers?
  • 02-19-2015
    MagicCarpet
    Superstar Components in England sell rebranded Novatec 9mm front and 10mm rear quick release through axles. These are commonly known as QR THRU. You need to be able to properly convert your hubs, but some people have successfully drilled out their existing end caps. A friend of mine has converted Hope hubs and used these and likes them a lot.
  • 02-19-2015
    bmike
    yes
    DT Swiss - RWS MTB steel
  • 02-19-2015
    wschruba
    I believe Nate was referring to the 9/10mm QRs. They're quite uncommon now, Hope is the only company that I can think of that makes a hub that is easily convertible anymore.
  • 02-19-2015
    Harold
    That may be with thru axles becoming more common
  • 02-19-2015
    AndrwSwitch
    If you don't already have a good QR skewer, that's the easiest and cheapest. Sheldon Brown was fond of internal cam skewers, like Shimano's. They have much higher mechanical advantage than a lot of the competition's, so "as best as I can" is pretty good, even for someone who never got into power lifting.
    On an aluminum frame, if your QR skewer's not leaving marks on the dropouts, it's not tight enough.
    BB7s don't open that wide. So you also may need to adjust your segmentations. Bikes ridden off-road trend to make noise. Can you actually feel it dragging, or is it just a sound?
  • 02-19-2015
    sgtrobo
    nah, i think it's just sound. Just a hideous, nails-across-the-chalkboard sound that makes it sound like I'm breaking $hit... (I am a bull-in-a-china-shop type, I break things all the time accidentally)
    bmike, you had the DWS on your Fargo? I'll drop the $$$ on them now if I can figure out that they definitely fit the Fargo.
  • 02-20-2015
    bmike
  • 02-20-2015
    bmike
  • 02-20-2015
    Volsung
    I had this issue when running 203mm rotors on my Big Dummy. I switched to 180s and it went away.
    I dunno if you could/should try a 160 in front, but it's an option.
  • 02-20-2015
    Harold
    I'm not sure if I'd want to do that if I was the OP. I'm about 175 and I really prefer a 180mm rotor on the front of most mtb's.
  • 02-23-2015
    ljsmith
    American Classic also has a conversion kit.
  • 02-23-2015
    sgtrobo
    Originally Posted by bmike View Post
    so i just got mine from JensonUSA.
    what's the deal with these, replace my skewers with them and just crank these suckers on tight, once you get the wheel nice and centered in the dropouts?
  • 02-24-2015
    AndrwSwitch
    I don't know if I buy that the RWS skewer is any better than a good cam-locking skewer if it's just a skewer and not an axle.
    Worth a try, I s'pose. OP, what kind of skewers do you have now? And I'm not sure how to ask, but do you know how to use them?
  • 02-24-2015
    Harold
    Yes, just crank the RWS ones down tight and then reposition the lever so it won't snag on anything.
    Did you just buy the 5mm ones? I don't think those are nearly as much of an improvement as the fat 9/10mm ones.
  • 02-24-2015
    sgtrobo
    dunno. they're not labeled at all
    uh....*laughs* I didn't realize there was a 'way' to use them? Stick them in, screw them on? No?
    well crap. I got these ones: DT Swiss RWS MTB Steel/Aluminum QR > Components > Wheels > Quick Releases | Jenson USA
    one for the front, one for the rear. i don't see any that specify 9/10mm
  • 02-24-2015
    Harold
    DT Swiss - Overview
    Shows the whole RWS lineup. They even make RWS thru axles. They call the 9 and 10mm ones thru bolts, but they work the same as their 5mm skewers. They're just fatter. And they require hubs that can accept them, hence all of my earlier questions about which hubs you have (which you never really addressed). If your hubs can't take different end caps that will work with the fatter skewers, then short of buying new wheels, the 5mm ones will be all that you can use.
    I find that the RWS stuff is less fiddly than regular QR levers. You don't have to get the nut just so so that when you clamp the lever it takes just the right amount of pressure. With RWS, you just hand tighten it and reposition the lever (it's clever that you can pull straight out and rotate it freely). Done. If DT ever makes a 15x150mm RWS thru axle that I can replace my Maxle with, I'll probably do that. Now that they're in the fat wheel game, they probably will at some point.
  • 02-24-2015
    sgtrobo
    DT Swiss - Overview
    I wasn't sure how to figure out the answer.
    2012 Fargo 3 | Bikes | Salsa Cycles is the bike. It reads, "Formula Sealed bearing" hubs, 32h. I saw that bmike had already bought these and used them on his Fargo so I assumed they would work for mine as well.
    that's good info, thanks. Sorry I'm so ignorant on this stuff, still a lot to take in. i know basically nothing about bikes. I just want to hop on and have a lot of fun riding them, so i have a lot of learning to do.
  • 02-24-2015
    Harold
    I will guess no end caps available for your hubs.
  • 02-24-2015
    Saul Lumikko
    Skewers have huge differences. Shimano internal cam ones can produce up to 8000 N clamping power if my memory serves me correctly. External cam and other inferior designs are less than half of that. 5 mm thru-bolt is right up there with Shimano skewers, they are also a good choice. Neither of these require any changes to the hub and are likely to at least reduce the rotor rub, if not eliminate it entirely.
    If your front hub has a steel axle, you can tap it to M6 and convert it into a bolt-on hub. Make sure you get good bolts so they won't stretch because of the torque you'll use to install them. Clamping force will be superior to any QR skewer or M5 thru-bolt. Any machinist with a lathe can do this for you in less than 10 minutes.
    If it has simple end caps that you can pull off, you can enlarge the current holes to 9 mm and you're ready to use a 9 mm thru-bolt. Any machinist with a lathe can do this for you in less than 5 minutes.
  • 02-24-2015
    AndrwSwitch
    Whenever you're not sure, post a pic. It won't always be true, but most of the time, if you have a compatibility question, the parts will look distinctive enough that someone who knows the system can tell by eye.
    MTB parts were surprisingly consistent for a while but now suffer from a ton of mutually incompatible standards. So you should have a pretty strong expectation that compatibility will be okay before you buy anything. Sounds like everything will work together and you might get the desired outcome this time, though.
  • 03-20-2015
    labeda14
    i have a salsa cro-mo fork on my single speed. when i switched from 160 to 180 rotors, i began to hear the dreaded "zing" when standing and mashing. no matter how much fiddling i did, i couldn't get the caliper far enough outboard to prevent the noise. after some looking, i noticed the disc tabs were powder coated. so i faced the tabs...now all is silent! Obviously this is not going to fix the flex issues, but it should give you enough clearance to not have to hear about it.
  • 03-20-2015
    sgtrobo
    oh wow, I hae 180mm rotors too! Maybe that's the problem. What is "disc tabs were powder coated, so i faced the tabs"? I don't even know what that means.
  • 03-20-2015
    labeda14
    HA! Sorry, the mounts on the fork itself that the disc caliper (or adapter) attaches to are called disc tabs. is it painted the same color as the fork legs or is it bare metal? if it is painted/powder coated, then take it to a shop and ask them to face the disc tabs. basically they will insert a special tool fitted with a cutting blade into the bolt hole and remove the painted finish down the bare metal. the special tool is required to ensure the surface remains parallel
  • 03-20-2015
    fourfa
    Another way to approach this problem - increase the free space between the pad and rotor. I'm only 180# but I found the BB7s (185F/160R) to be very inconsistent and underpowered on last year's 1000mi tour. Every time I took a wheel off, it would rub after. Every time I turned the bars, they would squeak. Sometimes brake power just wouldn't be there, I'd stop and fiddle with it, and it would come back. Tried all manner of adjustments, but if the inboard pad isn't just about touching the rotor, it will suck. That means it's always going to squeak, and zing under load.
    My general dissatisfaction led me to a front HY/RD brake. Both pads retract, and the free clearance seems much more on both sides. Despite that, the engagement comes fast and on my bike , the brake lever never comes close to the bar. I guess with the hydraulic stage in there, they can monkey with the motion ratios a bit. So far they have been more consistent and more powerful on the same size rotor. On a recent overnight trip I tried seven stops in a row from 28-30mph to zero, loaded with 65lb total rolling weight plus my 180lbs, descending Mt. Hamilton at 8-10% grade, using front brake only. No boil, no change in power from start to finish.
    Got a Spyre brake for the rear on the way, just for pad commonality and to finally get rid of the squeak and zing.
    For sale: 1pr BB7 brakes
    (BTW this is on a Vaya, not a Fargo. But they're close cousins)
  • 04-27-2015
    sgtrobo
    just wanted to poke my head in here and confirm.
    I got the DT Swiss RWS QRs a few weeks ago and finally installed them. I did a 23+ mile 'monstercross' ride, and today as I was standing and mashing through a bunch of deep gravel, it occurred to me that I hadn't heard any rotor rub during the entire ride
    yay!
  • 07-01-2015
    mikhaelc
    Thanks for this thread guys! I was having the same issue with front rotor rub, on a medium 2013 Fargo 2 @ 150lb rider weight, and was sad to give up my Salsa Skewers (although I kept the pretty orange skewer nuts).
    I fortunately had some spare Shimano XT skewers floating around my toolbox, and not only are they a lot less aesthetically obtrusive (tiny black levers instead of huge shiny things), but their clamping force is unbelievably more. One can tell just by clamping it.
    I'll update again if they don't solve the issue.
  • 07-02-2015
    mikhaelc
    The XT skewers totally fixed the issue.
  • 07-03-2015
    AndrwSwitch
    No surprise here. Glad you fixed the problem. :)
