Mukluk Seat-post: Straight or Set-back?- Mtbr.com
Results 1 to 5 of 5
    Reputation: Aushiker's Avatar
    New question here. Mukluk Seat-post: Straight or Set-back?
    I am in the process of specifying a build of a Mukluk frame-set and tossing up whether to go with a Thomson Elite SP-E116 Black 31.6 mm x 410 mm straight set-post or the Thomson Elite SP-E116SB set-back seat-post.
    Don't know if this makes a difference but will be fitting a Brooks saddle which has a limited adjustment fore and aft.
    So the question is straight or set-back?
    Andrew
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Mukluks are usually best fitted with a seatpost offering some setback.
    Especially Brooks saddles are friends with a lot of setback, so you might want to consider something with more setback: Thomsons only have 11 mm. I have two layback Thomsons on my bikes and I really like them, but with a Brooks I might run out of adjustment range.
    I think the real answer to this question depends on your body and the fit you're trying to achieve.
    Ideally, you'd hold off on spending the money on the Thompson and have the shop let you try a few seatposts they have lying around the shop to see what you actually need. Or bum a few seatposts off your friends if you're doing the build yourself.
    I write for the Dusty Musette.
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Yep, boils down more to fit for you than saddle brand or frame geo.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Reputation: farleybob's Avatar
    May 2012
    I tried putting a Brooks on my XL Muk with a Thompson Setback and it did not have enough adjustment. The rails on the Brooks are very short giving you little room to move the saddle back. I ended up going with a Selle Anatomica saddle which is just like the Brooks but with longer rails for better fitment options.
    I AM FAT!
    2016 Salsa Blackborow
    2018 Salsa Blackborow Mid
  1. Set back seat post >30mm
    By bclagge in forum General Discussion
    Last Post: 01-13-2018, 05:42 PM
  2. Back not completely straight -- HOW TO ADJUST SEAT?
    By dwagner in forum Beginner's Corner
    Last Post: 08-25-2014, 07:50 AM
  3. Set back seat post vs non
    By CyclesnIPAs in forum Bike and Frame discussion
    Last Post: 02-22-2013, 06:48 PM
  4. Mukluk seat post clamp torque
    By Davesnhere in forum Fat bikes
    Last Post: 12-29-2012, 12:28 PM
  5. set back seat post?
    By Wayne in forum General Discussion
    Last Post: 07-23-2012, 10:27 AM
