Min. tire size for Salsa Delgado's?- Mtbr.com
Results 1 to 7 of 7
    Re-friggin'-Lax!!!
    Reputation: WEBERTIME's Avatar
    Hey guys, just wondering what the min. width for a tire that could/you would, run on a Pair of Delgados? I saw they were 22.5mm wide according to their site, so I'm thinking (hoping since I already have a pair in this size) that 700x26 would work. Anyone with experience in this area?
    If necessity is the mother of invention, laziness is the deadbeat dad that knocked her up.
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    Ive run some 25c Conti Gatorskins on delgados before no problem.
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    If you can run sub-20mm tires on a 20mm rim...
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by WEBERTIME
    Yeah, the general rule of thumb is that the tires should be at least as wide as the rims.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    smallest tire I have run is
    Hi, for an MS150 ride I ran 20mm tires on the delgado rim. Going for that ultra low profile 1987 porsche 930 turbo 315/35-15 look.
    On the otherhand right now that same delgado has a schwalbe big apple 700x 60c tire.
    Non bike people think I am weird.
    -jv
    highly visible
    Reputation: GlowBoy's Avatar
    I've often run 23c tires on 22-23mm rims. Since some tires (Conti, Panaracer, etc.) run narrow, you could decide to stick with at least 25c to be on the safe side.
    One side benefit (if you have rim brakes) of running a tire not much wider than your rim is that you don't need to open the brakes to get the wheel on and off. Nice if you use a fork-mount bike carrier.
    "People like GloyBoy are deaf. They are partisan, intellectually lazy & usually very angry." -Jaybo
    Re-friggin'-Lax!!!
    Thanks Guys!
    gracias!
