ISO: Salsa v 1.0 Alternator Drop outs- Mtbr.com
Results 1 to 5 of 5
    Want to buy Salsa Alternator drop outs v1.0 to convert 2013 El Mariachi 2 to 12x142 TA. Part #s: FS1373 and FS1382. If you have a set not being used and want to sell, kindly let me know. Thanks!
    Professional Amateur
    Reputation: Henrythewound's Avatar
    Did you ever find these? I am looking as well. Will probably just order from the LBS but figured I'd ask if you found a different source
    i just ordered them online.
    Did you also purchase their deadwood thru axle or a different brand?
    This is what I bought from Worldwide:
    FS1315 Salsa Alternator 1.0 Hardware Set for 2013 Ti and all Steel frames
    FS1025 Maxle Stealth Rear Thru Axle: 12x142, 174mm Length, Standard
    FS1385 Salsa Alternator 1.0 Plate Right thru-axle M12x1.75 thread pitch, Derailleur Hanger with Fender MT
    FS1382 Salsa Alternator 1.0 Plate Left Thru-Axle M12
    I also installed an Angleset Headset -2degree to slacken it.
    2.0 Degree EC44-EC44 Angle Headset - To Suit Tapered Steerer Tube - Headtube Length:Set 2 99-106mm - Order now for 25/03 dispatch.
    Reducer Crown for 1 1/8" Fork?: Not Needed
    https://www.workscomponents.co.uk/
  1. Replies: 3
    Last Post: 09-23-2018, 12:46 PM
  2. Replies: 3
    Last Post: 09-24-2016, 04:55 PM
  3. Replies: 9
    Last Post: 06-17-2013, 12:49 PM
  4. Replies: 6
    Last Post: 09-09-2011, 03:55 AM
  5. Replies: 4
    Last Post: 03-16-2011, 12:10 PM
