increasing the "lockout" on a spearfish
Hello everyone,
I have an older spearfish, and i find myself wishing the lockup (or platform setting, or whatever you you call the damping force the climb setting has) had more "lock" to it. Is there a way to increase the "lockout" force, or to make it more dampened in the climb mode?
Thanks, and my apologies if this is a dumb question.
Try sending it to Suspension Experts in Asheville NC. They can "Push" it for you. You can call them and discuss if what you want is possible. Great folks and generally fast service
Push is actually a completely different suspension tuning company in Colorado. They are the only ones that can truly "Push" your shock.
PUSH Industries
Actually Push is not doing any work on forks or shocks. They sub out all their work to Suspension Experts. Unless this has changed recently. Push is now into product development
Good to know. That still bugs me though. Like here in Texas where they call any brand of soda a Coke.
Thanks, I will get in touch with Suspension Experts and see what they say. I assume this isn't something i can have done by my local bike shop? I have no idea how complicated these rear shocks are...
No. Most local shops, at most, will do a basic service including new seals, wipers, and fluids. What folks here are talking about doing is custom tuning, which involves replacing some of the internal parts to change the compression damping.
Another option you have would be to replace the shock with one that has better adjustments. The Cane Creek DBInline is HIGHLY adjustable so you can get it to behave how you like.
I live down the block from PUSH here in Loveland. In Nov 2016 I dropped my fork off and they did the work there. If you send it from elsewhere maybe they work on it elsewhere but I for me they did not.
Hello everyone,
I have the same question regarding the rear shock on a single pivot Spearfish. The stock shock, a Fox CTD Boostvalve L tuning never locked out for me. Actually it seemed none of the settings ever did anything. It acted the same in climb, descend or trail. Changing the rebound did nothing. The pressure was the only thing that had any effect. Others I know with the same frame and shock say the same thing.
I am considering moving to a new shock since they old one is near dead after 3 years and 5,000 km with no servicing. I may get a Rock Shox Monarch RL.
 Originally Posted by raymo853
i have the same question regarding the rear shock on a single pivot spearfish. The stock shock, a fox ctd boostvalve l tuning never locked out for me. Actually it seemed none of the settings ever did anything. It acted the same in climb, descend or trail. Changing the rebound did nothing. The pressure was the only thing that had any effect. Others i know with the same frame and shock say the same thing.
I am considering moving to a new shock since they old one is near dead after 3 years and 5,000 km with no servicing. I may get a rock shox monarch rl.
nnnnnnnnneccccccrooooooobuuuuummmmmmmmmppppppppp!
Pocket post or are you just an ass?
Sent from my SM-G900V using Tapatalk
Is your Fox shock is a performance series? If so, they are notorious junk. A Monarch RL should make a huge difference. Lockout will never fully lock out, all shocks have a blow off valve in the event you take a huge hit to avoid destroying the shock and keeping you from going OTB. And to answer your question, yes.
Yes my shock was a boost value peformance series. I bought the rebuild kits, but at the same time a Monarch RL. Going to use that, rebuild the old one and keep it as a spare. The Fox made me less than happy from day 1.
 Originally Posted by Raymo853
Yes my shock was a boost value performance series. I bought the rebuild kits, but at the same time a Monarch RL. Going to use that, rebuild the old one and keep it as a spare. The Fox made me less than happy from day 1.
First short ride with the Monarch RL and I prefer it greatly. So nice to finally have a lockout.
Second ride on the Monarch. My firm suggestion, do not rebuild any BoostValve Fox, just toss it, and get a Monarch RL. The Monarch is so remarkable better than the Fox was, regardless of its condition. (New, broken in, or worn out)
By SoftballGuy in forum Shocks and Suspension
Last Post: 01-06-2014, 05:06 PM
By Rumblefish29er in forum Salsa
Last Post: 07-28-2013, 04:42 PM
By bryanus in forum Shocks and Suspension
Last Post: 06-18-2012, 10:21 AM
By lubbockrider in forum General Discussion
Last Post: 01-24-2012, 07:54 PM
By bt in forum Niner Bikes
Last Post: 12-31-2010, 09:03 AM
- You may not post replies
- You may not edit your posts
Forum Rules
