Help finding a a freehub body or pawls for a Salsa branded hub?- Mtbr.com
Results 1 to 2 of 2
    Reputation: farley's Avatar
    I've got a "Rhymes With Orange" Surly Karate (2017, I think?) that came stock with Salsa hubs and I recently ended up with the freehub freeing itself in both directions. I got inside and found one pawl broken in half and the other two pretty worn down.
    My LBS wasn't able to identify a source for a new freehub body or for a new set of pawls. They were able to pull a set of pawls off of another hub that had died of other causes so I'm back up and running for now.
    My concern, though, is that I have a history of not being kind and gentle with freehubs so it's probably a matter of time before this happens again and I want to be prepared if possible.
    It's a Salsa branded hub but I believe it was actually made by Formula. I'm under the impression that Formula makes hubs that get sold under lots of different brand names so I suspect that somewhere out there, there has to be a source for either freehub bodies or pawls. Anyone know where I can find them? Or anyone know of other branded hubs that would use the same part so I can check for parts for those?
    Fat, tired.
    Oct 2018
    Quote Originally Posted by farley View Post
    I just put one of these on my Bucksaw with Salsa hubs. Works good...
    https://www.jensonusa.com/Race-Face-...tm_medium=AVLK
  1. Replies: 0
    Last Post: 01-05-2017, 09:12 PM
  2. koozer 6 pawls versus circus monkey hdw3 3 pawls, outdoor sound check
    By Forcemajeure in forum Asia + Philippines
    Last Post: 01-05-2017, 09:06 PM
  3. Mavic freehub swap question, 2 pawls to 4 pawls engagement
    By madsedan in forum Wheels and Tires
    Last Post: 10-20-2015, 03:38 PM
  4. XT rear disc hub: 2 pawls or 3 pawls?
    By SingleTrackHound in forum Shimano
    Last Post: 02-23-2007, 09:00 PM
  5. Dimension 12mm freehub body: 4 pawls or 3?
    By josiahdood in forum Wheels and Tires
    Last Post: 01-12-2007, 08:35 PM
