Fargo Rear Rack Options- Mtbr.com
Results 1 to 19 of 19
    Apr 2016
    Anybody familiar with rear racks that will work with the Fargo with the alternator dropouts other than the salsa racks? Bike will be mostly a commuter and $120 for a basic rack seems steep!
    Sent from my VS985 4G using Tapatalk
    I recently bought the Tubus Cosmo: tubus - Cosmo
    Very nice quality rack and works with the alternator dropouts!
    ''Anybody who thinks wood isn't magnetic, hasn't ridden a bike in the forest.''
    Apr 2016
    Thanks for that, but it's costs more than salsa's rack. I'll probably night the bullet and go with salsa.
    Quote Originally Posted by jbandt View Post
    Ah sorry, here in Europe the Tubus racks are much cheaper than the Salsa.
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    I have a Blackburn 'Central' rack that I have run on my Fargo for a few trips. Works just fine.
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Apr 2016
    Quote Originally Posted by Smithhammer View Post
    Thanks Smithhammer. How did you mount the lowers? Salsa hardware to the upper alternator mount or with a longer QR skewer?
    Ambassador of Chub
    Jul 2015
    I actually just used the included clamps, straight to the chainstays just ahead of the dropouts.
    Apr 2016
    Sounds good. Thanks again.
    Apr 2015
    Here's the Blackburn Central rack mounted to mine. the tabs for the "disk" mounts don't fit exactly flush into the alternator indent. there is about a 1/4" gap on both sides. but works just fine with longer bolts. Other than visually pushing the rack out a bit causing the panniers to not sit on a level surface. everything works just fine.
    Apr 2016
    Quote Originally Posted by GPcruiser View Post
ID:	1085740Click image for larger version.
    GPcruiser, did the blackburn come with longer mounting bolts? I'm assuming so.
    Apr 2015
    Yes. As I remember it came very well supplied with various bolt sizes and even the hose type rubber coated clamps. For half the price of the Salsa rack i think it is a great deal. Or you could always get the mounting kit for the Alternator rack that comes with bolts and spacers and mount just about any rack.
    Jon BALER
    The lower mounting bolt on the Salsa Alternator racks is 1 size larger than typical rack mounting bolts. For those who used a standard rack, did you have to enlarge the hole in your rack?
    Apr 2015
    Nope. worked with the existing holes.
    Reputation: JNKER's Avatar
    Feb 2016
    Is the Blackburn Central still going strong?
    Apr 2015
    Quote Originally Posted by JNKER View Post
    Indeed. Have an estimated 500 miles with 2 panniers attached and have had zero issues thus far.
    Apr 2015
    Does anyone know if the Alternator Low Deck Rack will fit on a Fargo?
    Jon BALER
    It will depend on what size tires. It should fit with road tires, but maybe not with mountain bike tires.
    This link has the dimensions at the end of the document
    http://salsacycles.com/files/tech/12...ack_INST_F.pdf
    Here is a photo of my alternator rack with 50mm fenders and 40 mm tires. Lots of clearance left
    https://www.flickr.com/photos/jon_ba...etaken-public/
    Apr 2015
    Looks like it's spec'ed to fit 2.1" Thinking of a big Apple swap soon and may have to stick with my Blackburn
    Reputation: likeybikey's Avatar
    Nov 2007
    Has anyone tried a Topeak Disc rear rack with the Fargo's Alternator dropouts? I would be using the rack with the Topeak baby seat, so it needs to install as designed--I don't want to jerry-rig it.
    Assuming I can bolt it on properly, I would want it to clear a 29x2.0 tire (which, sadly, my Cross-Check will not do as the tire rubs the rack hardware).
    https://www.topeak.com/global/en/pro...ii-rack-(disc)
  1. straggler rear rack options
    By vitaly66 in forum Surly
    Last Post: 12-04-2016, 07:09 PM
  2. Rear Rack Options on Farley
    By smoothie7 in forum Fat bikes
    Last Post: 03-04-2015, 01:44 PM
  3. Replies: 14
    Last Post: 09-26-2013, 08:37 PM
  4. Rear rack options for the Pugs?
    By trrubicon06 in forum Fat bikes
    Last Post: 02-08-2012, 09:35 AM
  5. Fatback Rear Rack Options?
    By redline814 in forum Fat bikes
    Last Post: 11-13-2011, 05:36 AM
Members who have read this thread: 7
