Fargo Questions: Tires & Brifters- Mtbr.com
Results 1 to 10 of 10
    Jun 2010
    I have a first generation Fargo. I use it mostly for road (commuting) and light trails. I have two questions:
    1) What tires are recommended for commuting? Can I put some 700x28 or 700x32 tires on the stock rims and will they produce predictable results?
    2) I am thinking of swapping the bar-ends for some brifters. I am thinking of two options. Am I crazy? Better solution? Purchasing some Shimano 105 10 speed brifters and adding a new 10 speed cassette and chain? How about some Campy brifters (I run campy on everything else), shiftmate, new cassette and chain. What do you guys suggest? anyone done this?
    Cheers,
    Guy
    Maybe just do Tiagra levers and keep your drivetrain the way it is. That way you can use a big cassette. The capacity is limited with Shimano 10spd road... unless you put a 10t pulley on it to increase the capacity slightly. The other option, if you want 10spd, is to do SRAM Apex. It has a large capacity rear derailleur.
    I like VIttoria Randonneur Hyper tires. With that bike I'd want to run at least 38c just because the bottom bracket isn't super high. Maybe even run Schwalbe Marathon Supreme or Big Apple LiteSkins in 2.0.
    Reputation: Outsider's Avatar
    The 9-speed Tiagra levers are great. I built up my Fargo with them in the beginning of last year and have had no problems at all.
    My outdoor blog: www.yetirides.com
    Jun 2010
    Quote Originally Posted by Outsider View Post
    Thank you both for the comments. much appreciated. Love your blog. What cool adventures!
    Guy
    those are Rollercams...
    Reputation: WTB-rider's Avatar
    Do the Tiagra levers work with discs or do they require an adapter like the Travel Agent?
    Truly a wealth of useless information.
    http://blackdogadventureteam.blogspot.com/
    Aug 2010
    bb7 road
    you can use the BB5 or BB7 Road version. They're the gray colored version of the BB disc brakes. They are made for short pull levers found on all road brifters.
    Quote Originally Posted by efraguiluz View Post
    Duh! I completely forgot about the road versions. Thanks.
    Jun 2010
    Does this mean that if I go with Tiagra Shifters then I need to change out something on my brakes too? I am trying to figure out what the post above means. More detail is much appreciated.
    GG
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by GuyGadois View Post
    GG
    From a stock Fargo that came with bar end shifters you would need to change the brake calipers. Stock calipers work with the stock levers which pull more cable than a Tiagra lever will. That's why you need the BB-5 or BB-7 road specific calipers with brifters.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Aug 2010
    GG
    I'm guessing you have the Gen 1 Fargo then like GT said you would have to swap out the bb7 mountain that have the black calipers withe the road versions which have a Gray caliper.
    http://www.sram.com/avid/category/283
    Now if you don't want to replace the calipers the you could use something like this
    http://problemsolversbike.com/products/travel_agents/
    that would increase the cable travel and allow you to use the mountain bb7's you do have. however I think you probably better off getting the road version. Just make sure that they are the road version and not the mountain ones.
