Fargo Flat Bar Frame Sizing- Mtbr.com
Results 1 to 2 of 2
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    I'm thinking of getting a used V1 Fargo as a replacement for my old steel 29er MTB. I've got a 160mm squish bike so the Fargo would be more of a commuter or XC whip.
    Typically I'd run it with flat or mtb bars and a 60 or 80mm fork. For bikepacking or general training I'd use drop bars and a shorter fork than stock, something like a CroMoto 26" 425mm A2C.
    Going with the longer frame would not only benefit the ability to run a flat bar, but also cut down on the toe-overlap in roadie mode.
    Thoughts?
    Bonus Question: Anyone think we could fit a 650bX2.5" tire in the back of this frame?
    Work - Utility GIS Analyst
    Party - 2019 Guerrilla Gravity Revved Trail Pistol Sz 3
    Positively negative
    If we are talking about traditional road bars there is about a 40-60mm difference in TT length to a equivalent flat bar bike. Dirt drops can be a different story. If you can hit a sweet spot then this may work by changing stem length. You also have to consider compatibility issues between road and MTB parts, mainly the brakes. Also, I don't believe the V1 was suspension corrected so that may play into things.
    And I don't think you'd have issue with a 650x2.5, though that will effect geo, being a smaller tire/wheel. I did see you mention a 650x3 in the other thread, which I don't think would fit, but I would guess your thinking of the WTB Trailblazer which is a 650x2.8 which should fit in a frame that can take a 29x2.3.
  1. To use a flat bar on salsa fargo?
    By Touma in forum Salsa
    Last Post: 05-29-2018, 12:49 AM
  2. 29er Fargo and sizing for smaller women?
    By Gyro_t in forum 29er Bikes
    Last Post: 12-02-2013, 01:23 PM
  3. 29er Fargo and sizing for smaller women?
    Last Post: 11-18-2013, 06:48 PM
  4. WTT 56 Vaya frame/fork for M Fargo frame
    By deuxdiesel in forum Salsa
    Last Post: 08-18-2012, 10:35 PM
  5. 2011 Salsa Fargo Sizing..help
    By pghmtnbiker in forum Salsa
    Last Post: 05-12-2011, 10:57 AM
