dos niner chainline question- Mtbr.com
Results 1 to 2 of 2
    Dec 2004
    Hey all you (all three of you, that is) dos niner owners. I'm building mine up, and it actually seems like a 108mm bb could work in there. I have an xtr 112 with room for 2 spacers on the non-drive side. 2 spacers is .25" which is 6.5mm. Do the math and a 108mm should work fine, yes?? Thanks for your thoughts.
    Depends on the tire
    You may want to set it up and look at the clearance with the tire when the chain is in the Granny and you top cog in the rear. If you move that chainline to far in, and use a wide tire, it could rub the der. on the tire. Check it out in the stand and disassemble if necessary.
  1. Dos Niner or custom steel?
    By Swami Scott in forum Salsa
    Last Post: 05-20-2008, 02:07 PM
  2. XL Dos Niner Built!!
    By MichiganClydesdale in forum Salsa
    Last Post: 06-06-2005, 06:53 PM
  3. Salsa Dos Niner review
    By mikesee in forum Salsa
    Last Post: 12-06-2004, 11:57 PM
  4. F'ing chain keeps falling off!!!!!!!
    By liaudio in forum Singlespeed
    Last Post: 06-24-2004, 07:26 AM
  5. Adjusting chainline question......
    By KMan in forum Riding Passion
    Last Post: 06-18-2004, 07:33 AM
