Crankset: Will SLX FC-M670 triple directly replace FC-590 on El Mariachi?- Mtbr.com
Results 1 to 3 of 3
    Dec 2005
    Go buy the SLX FC-M670 crankset from eBay for $96 to replace the worn and damaged original FC-590 crankset?
    My 2013 El Mariachi 3 (3x10) crankset is worn (purchased the bike used) and has a few missing teeth along with a fairly stretched out chain (3/8" stretch over 12" length of chain) that apparently may have worn the chainrings a bit.
    I want to replace the crankset (because new chain rings would cost almost as much as a new crankset). The original crankset is a Shimano FC-590-10 (Deore 10 speed base level).
    I plan to use FC-M670 (SLX level) 10 speed crankset to replace it. It uses the same (and comes with a new) SM-BB52 bottom bracket that came with the bike originally. Good plan? If not, what should I get instead?
    Also new chain and new cassette (11-40t Sunrace)
    73mm shell.
    I may go 2x11 one day, but for now want the same wide range and original-ish drivetrain.
    Dec 2017
    Should be a drop-in replacement. You can see the details of each here:
    http://si.shimano.com/pdfs/ev/EV-FC-M670-3396.pdf
    http://si.shimano.com/pdfs/ev/EV-FC-M590-10-3207B.pdf
    If you don't want to go to 2x or 1x, looks like a good plan. What range is the current cassette? Make sure your derailleur can handle the range of the sunrace. The jockey wheels on your derailleur may also be worn, so check those if you haven't already.
    Dec 2005
    Quote Originally Posted by Sparkman999 View Post
    just what I wanted to hear, thanks!
    I have already installed the new 11-40t cassette and the derailleur does work fine with the b-screw adjusted out a bit. But I will need a couple extra links on my new chain.
  1. Giant Fatty For $590
    By Flucod in forum Fat bikes
    Last Post: 05-13-2019, 06:16 AM
  2. Thule 590 v2 - TOO Narrow?
    By flen in forum Cars and Bike Racks
    Last Post: 05-15-2015, 07:45 AM
  3. Shimano XT M780/785 and SLX M670/675 crankset chainline info needed
    By guim in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2013, 05:46 AM
  4. Great deal on slx m670 crankset!
    By psuambassador in forum General Discussion
    Last Post: 06-13-2013, 05:27 AM
  5. M552 triple crank vs. 2013 SLX M670 triple crank
    By tryinghardrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-01-2012, 05:31 AM
