Carbon Firestarter Duro Crux Clearance- Mtbr.com
    Oct 2015
    Does a carbon Firestarter fork have enough clearance for a Duro Crux 29x3.25 tire on i45 rims?
    Alternatively, how much clearance is there in a carbon Firestarter fork when using 29x3.0 tires on wide rims?
    TIA
    Edit: I found a video of the carbon Firestarter with 29x3.0 tires and it looks like it has more than enough room to spare for another quarter inch...
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
    Here is a mock up shot. I pulled the front wheel and tire off of my lefty fork and mocked it up in my deadwood for you. The thru axle from the Salsa fork was close to the same size as the bearings in the lefty hub, so this is a pretty accurate placement. Tires are mounted on Hugo rims
    Untitled by tim_w_sage, on Flickr
    Oct 2015
    wow, thank you! this is more than i was thinking i would get. i wasn't even expecting a reply.
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
    Quote Originally Posted by buell View Post
    No problem, I just happened to have all the stuff laying around.
  1. Duro Crux & Miner arrived!
    By bikeny in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 01-03-2019, 09:57 AM
  2. Replies: 5
    Last Post: 10-12-2016, 12:57 PM
  3. 29+ with Firestarter Carbon Fork?
    By CrashTheDOG in forum Salsa
    Last Post: 08-06-2015, 11:13 AM
  4. Firestarter steel fork tire clearance?
    By canyonrat in forum Salsa
    Last Post: 03-21-2014, 01:06 PM
  5. Carbon firestarter fork?
    By captnpenguin in forum Salsa
    Last Post: 03-04-2014, 03:29 PM
