Alternator v1 vs v2- Mtbr.com
Results 1 to 2 of 2
    Oct 2015
    Alternator v1 vs v2
    So, what's the difference?
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
    Oct 2015
    Quote Originally Posted by buell View Post
    I asked Salsa. Here is their response:
    The V2 Alternator plates were designed to work with our carbon Woodsmoke and Mukluk frames. They feature either a sliding or fixed position plate that offers different wheel positions and movement in in the plate rather than in the frame like the V1 dropout. Frames made for V2 plates are not compatible with V1 plates and frames designed for V1 plates are not compatible with V2 plates.
    Further, because the 2.0 plates are designed to handle axle position and tensioning, the actual tensioning mechanism is different with built in tension and anti-slip features that are designed separately for drive and non-drive side tom combat different forces from braking and pedaling uniquely.
    I hope this helps.
    Matt
    Matt Reeve
    Warranty and Customer Service
  1. 142x12 Alternator
    By ratherbeintobago in forum Salsa
    Last Post: 07-03-2014, 03:31 AM
  2. Alternator bolt kit?
    By adinpapa in forum Salsa
    Last Post: 11-12-2013, 12:23 PM
  3. El Mar alternator swap- 135 to142
    By ru-tang in forum Salsa
    Last Post: 10-30-2013, 01:25 PM
  4. Alternator dropouts--what material
    By floxy in forum Salsa
    Last Post: 08-05-2013, 10:35 AM
  5. Alternator dropouts -- in or out?
    By Plum in forum 29er Bikes
    Last Post: 06-03-2012, 07:02 PM
