Alternator bolt kit?- Mtbr.com
Results 1 to 6 of 6
    I don't mind dirt caked on my Selma Ti SS, but I don't like seeing rusty bolt heads in the Alternator dropout.
    Any ideas if there is a stainless or titanium bolt kit available anywhere?
    Would Ti even be a good material for this?
    Paragon Machine Works has Ti and stainless bolt kits for sliding dropouts. You might check with them to see if they have bolts of the right size and threading.
    inquiry sent to Paragon. Will let you know.
    Here is the Alternator bolt list:
    4. Swing plate fixing bolt (2), M8 x 1.25, 16mm
    5. Upper pivot bolt (driveside), M6 x 1.0 w/washer, 16mm
    6. Nylock nut (driveside), M6 x 1.0
    7. Upper pivot bolt (non-driveside), M6 x 1.0 w/washer, 22mm
    8. Set screw (2), M4 x 0.7, 18mm
    Paragon just offers #4.
    For now, a harder search for these isn't worth it to me.
    Though if Salsa offered a complete Ti bolt kit, I'd probably buy it.... wink wink
    Smile Ebay Ti Bolts
    Quote Originally Posted by adinpapa View Post
    I also have a Ti Selma and am replacing all the steel bolts with Ti. There are several listings for Ti bolts on ebay, so just type in the above specifications and "titanium bolt" and you should have several options. You'll have to do some digging, but all the more gratifying it'll be once your bike is all tricked out.
    Oct 2012
    The UK distributer has this listed in it's Salsa frame spares category.
    Ison Distribution
    edit to add: seems these are not Ti bolts, just bolts for Ti frames only.
