29" non-boost wheelset for Timberjack 2017 GX1- Spacer question- Mtbr.com
Results 1 to 5 of 5
    May 2017
    Hey All - if this question has been answered many times already, I apologize. I just couldn't find it!
    I have a non boost 29" complete wheelset available to me that I want to have for my TJ which I believe is a boost factory set up.
    details of what is available to me:
    it's not fancy but would be fun to have for my GX1
    WTB i23 Race 29" wheelset, SRAM x9 Hubs non boost
    front 100x15mm with 2.3 WTB TCS Vigilante
    rear 142x12mm with WTB 2.25 TCS Trail Boss
    I believe I just a hub conversion kit?
    in this link, https://www.velofuze.com/boost-hub-adapters/
    does anybody know which one I would need?
    or am I way off on what I need to do.
    Thanks for the help -
    May 2017
    The front is the easy one, there is only one choice and you only need to get one interface to line up (the rotor/caliper), so that should go easily.
    The choice for rear is a bit trickier, since you need to get 2 interfaces to line up (the rotor/caliper and the cassette/chainline). If you can re-dish the wheel, then the rear kit with the 6mm spacer would be the better choice, since it will maintain the chainline, but you need to dish the wheel and keep it true in the process. If you can't redish the wheel, then you would need the kit with the 3mm spacers. This wont require redishing, but will basically move the cassette inboard 3mm, which might make the largest gear more difficult to use. If you don't know what dishing is, use this option.
    Salsa also has (or at least had) some different dropout plates that you could swap in to use non-boost wheels, but that requires more bike-side work, and would make it more difficult to swap the B+ wheels back in.
    May 2017
    Thank you very much for the reply and explanation. Not sure I want to tackle dishing the rear but Iím sure my LBS would help if I want to go that route.
    Reputation: Darth Lefty's Avatar
    Sep 2014
    The Alternators and the Boost spacing of the frame give you two options at the rear. You can do the Boost conversion on the wheel, or you can use the de-Boost Alternator spacers on the frame.
    May 2017
    Cool. I like the wheel option so I can swap back and forth when needed. Thanks for your input on this. I have not done much work with wheels and hubs on bikes but it seems pretty straight forward once you do some research and get some good advice from the good people on this forum.
  1. Pony Rustler Alloy GX1 vs Carbon GX1
    By velcipede in forum Salsa
    Last Post: 12-03-2017, 04:24 PM
  2. 2017 Pike Non Boost vs. 2018 Pike Boost....Boost worth it?
    By bwj75 in forum Shocks and Suspension
    Last Post: 11-09-2017, 02:21 PM
  3. 2017 Salsa Timberjack GX1 Upgrades
    By Wigniter in forum 27.5
    Last Post: 09-14-2017, 01:16 PM
  4. Timberjack GX1 Availability
    By jackamick in forum Salsa
    Last Post: 05-31-2017, 07:14 PM
  5. GX1 10 speed vs. GX1 11 speed derailluer
    By Bos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2016, 09:16 AM
