23 pound Salsa Caballero - dual discs.....- Mtbr.com
Results 1 to 16 of 16
    Mileage Junkie
    Finally got her done. I'm going to commit to FS this time, my trusty Kona Kula Primo was sold to keep from tempting me to keep riding the hardtail.
    23 pounds (a hair over actually), dual discs, 1498 gram wheels thanks to Mike Garcia, foamie grips which rule, Minute 2 which is ever so smooth, way better than the Marzocchi I was running before (controlled vs. sloppy travel), Marta SL's, pimpin ride. Have to dial it in, but wanted to show the pics. I love that carbon SLR too, it's been on like 3 different builds. I consider it birth control.......
    Reputation: Gripshift's Avatar
    That's a very nice bike... How much travel front and rear? What flavor of Continentals are you running? I
    Mileage Junkie
    Thanks...
    Front has 100mm, rear has 100mm, so it should balance out nicely.
    Tires are Conti Super Sonics. They were carry overs from another build, been good though.
    See pic for logo.....
    Mileage Junkie
    Explorer for sure, they were like 440 grams according to my sheet. the others were WAY too light for me. The knobs look exactly like my old explorer pro dual-compounds, the ones with the orange stripe up the middle.
    I love Pisgah
    Reputation: Duckman's Avatar
    One can tell by the blue banner they are SSs. But..theres the ExploreR SS(440gms), and then theres the TwisteR SS(370gms). Which are they? Note I cap'd the "R" because you can see the last letter before the SS logo. Could be either tho....Can't see the center knobs enough to tell.
    Reputation: ryan123's Avatar
    You will love that bike more every time your ride it!!! I have a Caballero too, mine is just a bit over 23 pounds too... awesome ride and different to everything else out there! Only had mine about 6 months.
    Way to go brother!
    Is my rear tire flat?
    Reputation: dlbennett's Avatar
    Nice Salsa!
    Is that a seat on those rails? Really nice build. Mine came in at 27.5 with bar ends. You know, even at that weight it climbs so well. I launched off of 1.5-2.0 drops last night and it handled it very well. I would like to swap out the RS Duke for something more beefy and stiffer.... but for now it works. Enjoy, for now I will swap back and forth between the cabby and the Ti hardtail.
    Dennis
    Liberty Lake Wa.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    Yes, nice.. [ lose the blue tie-lock.]
    R.
    It is inevitable ...
    Quote Originally Posted by Duckman
    I was wondering as well but the 2.1 gave it away...
    really nice bike and the door in the background is quite beautiful as well!
    I love Pisgah
    Duh! Your absolutely right(on the 2.1 vs 1.9).
    Damn, I must be slipping.
    Mileage Junkie
    Don't like the blue zip tie??
    I had neon pink, yellow, and blue, figured blue would be the LEAST ugly. haha......
    Quote Originally Posted by 10kman
    Some have put the IRD seat collar in place of the Salsa flip lock to save some more weight. I am going to do that.
    Also you may want to put some protective tape around the top tube by the seat tube where the three cable housings run down, because under suspension travel the housings move alot and will scrape the paint off in one ride. I KNOW from experience.
    Super nice build. How much do you weigh, and what settings do you have for :
    tire pressure
    + air in the rear shock
    - air in the rear shock.
    I am trying to dial in my caballero and am having a hard time finding the right settings.
    Mileage Junkie
    Have no fear......
    Have no fear, I put protective Campy tape all over the bike to hopefully ward off the dreaded cable rub. It won't help for the long haul though, haha, but it's worth a shot.
    I weigh 145, 150 loaded with water and such, I used 150 +/- in the shock, and it sags about 1/2" on the shock shaft. Seems okay, a little stiff over the little stuff, but it's good overall. I did 150 and THEN took the pump off, so I may have lost a little bit, but it works well for me like that.
    -10k
    Trail rider and racer
    Reputation: Trevor!'s Avatar
    Nice build and even better overall weight. I am curious about your saddle position, but whatever works for you is good. Speaking of saddles that older SLR model is my favorite.
    Trev!
    what size frame, how tall are you?
    I am looking to do a similar build. I am 6ft 1in and think I need a 20inch. probably I'll go with the RS Reba shock.
    Mileage Junkie
    Trevor -
    The saddle feels decent where it is right now. I like to be over the BB as much as possible, and for some reason, that SLR I like pointed down. My others are pretty much flat, but same BB position area.
    It's an 18" frame too, I'm 5' 11", but have a 34.25" inseam (to -dude-).
  1. Light Salsa Caballero
    By TheOldMan in forum Salsa
    Last Post: 06-08-2005, 12:42 PM
  2. Any Clydes on a Salsa Caballero?
    By endoMaster in forum Salsa
    Last Post: 05-11-2005, 07:55 AM
  3. STOLEN - Salsa Caballero
    By brownshoes in forum Salsa
    Last Post: 04-27-2005, 08:18 PM
  4. STOLEN - Salsa Caballero
    Last Post: 04-27-2005, 03:48 PM
  5. what seat collar for a salsa caballero ?
    By caballero in forum Salsa
    Last Post: 01-04-2005, 01:37 PM
