2018 Timberjack Frame questions- Mtbr.com
Results 1 to 2 of 2
    Aug 2016
    Hi everyone!
    I've been considering building a bike on a 2018 Timberjack Frame but had a couple of questions.
    1 - Anyone know where I can purchase one? I see that they are 2 AL frame colors for 2018 and they retail for $399 us. However, when I call my local dealer, they said they don't see any to order. They only have full builds available.
    2 - I'm trying to understand about the rear axle options. Am I reading it correctly that if I purchase the boost reduction kit and use a QR derailleur, I should be able to my older style skinny 29er wheels with QR skewers?
    Sent from my Pixel using Tapatalk
    Reputation: MountainBored's Avatar
    Aug 2016
    1 - I bought a slightly used frame because good luck getting one from a shop
    2 - yes. My build is almost done and you need boost reduction kit and 135mm QR Alternator Drop-Outs for the frame for your old 135mm QR rear hub. And a skewer. The derailleur is not part of the equation. You need the correct IS to Post Mount rear brake adapter (correct rotor size) to add to the Alternator Drop-Out to mount a brake (unless you have IS mount brake already). My frame came with the boost 148mm drop outs with 12mm threaded axle hole and through axle. I am saving those parts for the future. I had to buy the 135mm QR drop outs and the boost reduction kit. The boost kit has the longer hardware you need.
  1. 2017 Salsa Timberjack 29 NX1 vs 2018 Trek Roscoe 7
    By Gravity Check in forum Bike and Frame discussion
    Last Post: 09-05-2017, 11:53 AM
  2. Replies: 0
    Last Post: 08-10-2017, 04:52 PM
  3. Replies: 0
    Last Post: 03-27-2017, 01:39 PM
  4. Norco 7.2 Charge or Timberjack?
    By Hyder88 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-06-2016, 06:55 PM
  5. Trek Stache 9 or Salsa Timberjack?
    By MTBAtlanta in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 07-26-2016, 09:01 AM
