2018 Fargo Ti Tire/Wheel Size vs. Drivetrain- Mtbr.com
Results 1 to 5 of 5
    None
    Reputation: TheHamster's Avatar
    I am building a new Fargo Ti and want to be able to use all possible wheel and tire sizes. If I build it with a triple will there still be enough clearance for a 27.5 x 3 tire or even 29+ tire or do I have to go with a 1x to use these sizes? Thanks for letting me know.
    Oct 2015
    I don't think anyone makes a boost spaces triple. I could be wrong.
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
    None
    Frame is supposed to accommodate standard triples with standard cranks/BB. I happen to have a set of 29+ wheels/tires with standard hubs. I suppose I will have to install the triple and chain and see how much clearance I get to the tire.
    Oct 2015
    A standard spaced crank with a boost spaced cassette may cause problems. Also the chain may hit a 29x3 tire in the granny gear. I have the original Deadwood with a boost 2x XT crank and 29x3 Chronicles, and I can tell you that the chain gets very close to the tire.
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
    None
    Ok. Thanks. It looks like I will not be able to easily transition between wheel/tire sizes unless I keep standard cranks with standard hubs. But then the gearing might not be optimal for each wheel size anyway. I have the adapters to run 142x12 which I have on hand and liked the idea of making it more versatile for unloaded gravel riding as well as some on road riding. So I will stick with standard cranks and standard triple or double for now.
  1. Fargo tire size
    By rcnute in forum Salsa
    Last Post: 11-25-2015, 01:47 PM
  2. Fargo 2 vs Fargo 3
    By windhorze in forum Salsa
    Last Post: 09-09-2014, 04:46 AM
  3. Replies: 22
    Last Post: 08-13-2012, 10:55 AM
  4. Old Fargo or New Fargo?
    By cfpete in forum Salsa
    Last Post: 03-14-2011, 06:02 PM
  5. Fargo Steel vs Fargo TI
    By surly73 in forum Salsa
    Last Post: 03-12-2011, 04:53 AM
