2014 spearfish 2/horsethief 2 sizing for 5'8" rider- Mtbr.com
Results 1 to 10 of 10
    Apr 2016
    just looking for feedback from folks more knowledgeable than I:
    So, i'm bikeless after mine got stolen this past weekend, looking to replace it ( hardtail by another manufacturer, but no current stock available, even if I move up to their Full Sus. model )
    Looks like great prices on 2014 Salsa SF 2 & HT 2 near me, but the Salsa size guide puts me in a small, of course only Medium available.
    they are currently in the $1800 - $2000 range, which is at the VERY TOP of my budget.
    So, would I really be pushing it with a medium? would shortening up the stem make it acceptable?
    The closest dealer is a 3 hour drive ( 1-way), if the medium is absolutely NOT a good idea, i'd pass it up.
    but, if there is a reasonable chance that with a little modification the medium might work, this would be an awesome upgrade from my ex-bike, and the drive might be worthwhile.
    Maybe if I talk them into swapping out the 29s for 27.5s the med might be the ticket? or am I smoking something there?
    I have found a 2015 SF 2 in my size, but its $200 over my budget and further away, but perhaps the extra $ is worth it? ( newer & my size! )
    Thanks in advance for any thoughts!
    Reputation: brentos's Avatar
    As a reference point, I'm 5'11" and on a large Horsethief. They recommend a med at my height. I'm happy with the fit, but I like my bikes big. Also, the Horsethief geometry lends itself well to short stems...running a 60mm on mine.
    MFG
    MFG is offline
    I'm 5'9" and ride a medium 2014 El Mariachi and a medium 2015 Horsethief.
    In my experience, the Salsa sizing guide (a useful baseline reference) tends if anything toward undersizing the bike to the rider, i.e. a rider at the too tall/too short end of the sizing limit for two given frame sizes (175cm in the case of both the S/M Spearfish and S/M Horsethief) will probably find him/herself more comfortable on the larger frame. I loved the fit of my medium El Mariachi and worried that I might find the medium Horsethief too large, but that has not turned out to be the case at all. I was sure that I would at least shorten the stem (stock is 70mm), and while I still might do this, I have not found it immediately necessary. I have ridden a small Spearfish, and found it uncomfortably tight, with the seat jacked way above the handlebars. It was not a fit deficiency that could have been corrected with a stem swap or more spacers- the frame was simply too small. I have also put myself aboard both a large Horsethief and a large Spearfish, and was surprised that, while neither was perfect, each offered a more workable fit than the small-sized option.
    Shorter answer: I won't guarantee that the bike will be a good fit, but I do think that it will be worth the drive to find out, especially if you can get a good deal. Just try to have an open mind while you ride the bike. Don't try to talk yourself into or out of the bike because of a general guideline on a webpage (as I almost did!). Best of luck. Either will be a great bike.
    Apr 2016
    Thanks for the input you guys...
    Looks like i'm heading out there to test ride that Medium spear or thief after all!
    MFG: Thanks for spending the time to put a full thought process down along with your personal experiences.
    I usually try to let the bike talk to me about fit & feel, and listen to how the bike folks see the fit from outside the bike... sometimes they will see something that I don't feel because i'm excited about an awesome new bike!
    I also need to think about what to get my 12 y/o son - he's riding a cheapo, but still loves to go riding. I'm almost afraid he'll be dragging me out way too often if I get him a real bike!
    Thanks again!
    Good luck, though I think the medium will be great for you. I'm 5'8.5" and ride a medium 2014 Spearfish and it fits great. You can always run a shorter stem. I run an 85mm. Let us know how it goes!
    I'm 5' 9" and ride a medium Spearfish.
    Check with your local LBS, as the 2015 Spearfish 3s are marked down to $1699. Last my LBS guy told me, there were still lots left in stock. To that end, the 2015 El Mar 2 is also available at that same price point.
    Quote Originally Posted by cbiddick View Post
    Thanks again!
    MFG
    MFG is offline
    Yes! Let us know how it goes for you!
    Reputation: DanoXC's Avatar
    Dec 2009
    I'm 174cm and ride medium 2015 Salsa Spearfish Carbon. I'm currently using a 70mm stem and 730mm handlebars
    Have even used it with a 60mm and 80mm stem and all felt fine but I normally prefer a shorter stem.
    Sizing feels fine with a zero set back seat post.
    Apr 2016
    Thanks everyone - Made the drive, rode the Medium, they put on a shorter stem for me and that sealed the deal. Felt much better.
    then had to decide between the 2 or the 3 build. in the end, I walked out with the Orange Spearfish 2, talked them into setting it up tubeless for me, because I have goatheads galore in my area. The tubeless ready of the 2 build got me.
    In truth the stand-over is just a hair tighter than I like, but i'd say that its right around 3/4 inch, maybe an inch on the outside ( as long as my nards aren't hanging low that day, lol ).
    I'm pretty pumped, i like the orange, though it is not as bright as it appears in photos.
    Thanks for talking me into making the drive, I know I will love this bike for a looong time!
    Cheers, Chris
    MFG
    MFG is offline
    Congratulations!
    The Bible of Bike Tests guys did a video review of that bike last year, and they were quite keen on it. I would have considered one myself had it been available.
    Yes, more standover is never a bad thing, but I've never found a bike with a tight fit to have been as problematic as I had expected.
    Great call on going for the 2, which comes stock with tubeless-ready rims. It sounds like you would have been making the swap anyway.
    You've got yourself a great bike. Enjoy!
  1. Horsethief of Spearfish?
    By Clink in forum Salsa
    Last Post: 09-29-2015, 01:49 PM
  2. Sizing Horsethief frame (6'2")
    By peteer01 in forum Salsa
    Last Post: 12-15-2014, 02:25 PM
  3. 2014 Spearfish and Horsethief in house
    By gkler in forum Salsa
    Last Post: 05-31-2014, 01:30 PM
  4. 2014 Salsa Spearfish Sizing
    By neil.beltchenko in forum Salsa
    Last Post: 04-02-2014, 09:56 AM
  5. Replies: 17
    Last Post: 06-26-2013, 04:43 PM
