2014 Horsethief 1 Fork Question.- Mtbr.com
Results 1 to 9 of 9
    Reputation: Cycle64's Avatar
    I have a custom build to begin with and thinking I might toss a Pike on the bike, as I want 34mm stanchions. Questions is has anyone went to a 140mm fork on these yet. If so how has it worked out. I'm happy with the steering with the 130mm Revelation I have one it now.
    Mayo Clinic Phx. Kidney TX 06-20-2019
    Quote Originally Posted by Cycle64 View Post
    If you search this forum, you'll see that Salsa has stated that running a 140mm Pike on the Horsethief will void the warranty due to the longer axle to crown measurement. They say a 120mm Pike is the most travel you can use and still keep your warranty intact.
    Thanks good to know.
    Mar 2006
    pike 120 has the same ac to a revelation at 130
    got a pike at 120 on mine, best fork I have ridden.
    Quote Originally Posted by paris View Post
    Do you happen to know what the H/A is with this setup? I'm loving this bike but being heavy I don't like the flex of 32mm forks.
    I was thinking the new MRP Stage fork, but its 6mm too tall AC height.
    It seems like the Pike @120 is the way to go if you are looking for something stiffer.
    I wonder why there are so many restrictions on the forks available for this bike, it seems like there aren't that many options that don't void the warranty. Could Salsa do a little testing and expand the options available? The thing I always loved about Salsa was that you could hang tons of different parts on them. The Ibis Ripley can run 120-140mm forks . . .
    I think they are playing it safe with this one. The head tube area seems pretty stout on these bikes. For me it's not like I want this additional fork for hucking and such! Just don't like the deflection of 32mm tubes. It's on reason I got away from 29'ers early on.
    Spoke with Salsa and they are pretty firm on the numbers. Even the Pike at 120 with have a A/C close to 538 if the statement above is correct. So that now has me thinking maybe to get a 34 I might consider the X-Fusion Trace RL2.
    X Fusion Shox - Trace RL2
    Axle to Crown: 546mm @ 140mm, so in the 120 setting it should fall within range.
    Mar 2006
    Just checked head angle,
    pike 120
    head angle 68degrees
    tires front 2.3dhf
    rear ardent 2.4
    Hope this helps
    mike
  1. 120mm fork: Pike or Fox 36? (2014 Horsethief frame build)
    By peteer01 in forum Shocks and Suspension
    Last Post: 06-18-2014, 11:59 AM
  2. 2014 Horsethief vs ?
    By Twowheelchris in forum 29er Bikes
    Last Post: 05-10-2014, 02:12 PM
  3. 2014 Salsa Horsethief
    By lawfarm in forum 29er Bikes
    Last Post: 03-04-2014, 07:11 AM
  4. 2014 Horsethief 1
    By Jrcamp3 in forum 29er Bikes
    Last Post: 02-13-2014, 11:27 PM
  5. 2014 horsethief bars
    By nikj in forum Salsa
    Last Post: 01-24-2014, 02:23 PM
