2014 Horsethief 1 custom build.- Mtbr.com
Results 1 to 5 of 5
    Reputation: Cycle64's Avatar
    What crankset is the proper type for this width BB. I am using my xtype cranks 68/73 but the crank arm slips off after a few days of riding. I think the spindle is too short for the 92mm PressFit BB. Salsa site states use, Mountain 1x or 2x compatible; Max chainring sizes 1x (34T), 2x (38/24T). I looking online and not sure which Shimano crankset is the correct one. I would like a mid level dual ring 10 speed crankset.
    Would use another brand if needed, just like Shimano cranksets.
    Mayo Clinic Phx. Kidney TX 06-20-2019
    Reputation: flyinmike's Avatar
    Dec 2005
    I just saw this ------> BB92 service / repair
    Talked with Salsa this morning. They are going to check what part number they use on their builds. As it is not the spindle length but maybe the BB that is causing the issue,.
    Looks like LBS did not press in the drive side correctly. It was almost an 1/8th out form sitting correct in the BB shell. Hopefully that is all it was!
    Dec 2005
    That would do it..
  1. 2012 Horsethief Custom Paint Job
    By Spudman003 in forum Salsa
    Last Post: 09-01-2015, 06:39 PM
  2. 2014 Horsethief 1 custom build.
    By Cycle64 in forum Salsa
    Last Post: 10-20-2014, 10:50 AM
  3. 120mm fork: Pike or Fox 36? (2014 Horsethief frame build)
    By peteer01 in forum Shocks and Suspension
    Last Post: 06-18-2014, 11:59 AM
  4. Replies: 0
    Last Post: 06-18-2014, 11:23 AM
  5. 2014 Scott Scale 700 RC Custom Build!
    By Stuckinmuck in forum 27.5
    Last Post: 11-26-2013, 08:36 AM
