2008 El Mariachi EBB Replacement?- Mtbr.com
Results 1 to 6 of 6
    My crank arm just broke off this weekend and part of the EBB it threads onto broke off, too. Anyhow, love my El Mar and not looking to get rid of it. So, I need new EBB and cranks. I am running it SS. Would this EBB from Niner work on the El Mar?
    Niner Biocentric 30 EBB > Components > Drivetrain > Press Fit | Jenson USA
    Or any other recommendations?
    Oct 2015
    what's the point of an ebb when the frame uses alternator drops?
    No alternator dropouts in 2008 ....
    Oct 2015
    It has a BSA BB, right? If so, take a look at this: Trickstuff
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
    Oct 2011
    you should be able to fit a Bushnell eccentric in there. They are pretty bulletproof, just make sure you release the wedges when you go to adjust it. If you just loosen the bolts it won't release, you have to tap the wedges loose first.
    Reputation: baabaa's Avatar
    If it was me, I would just go another Bushnell. Had no issues with mine on a 07 el mari. I can see why a niner ebb wouldn't work if it was the same size. I think the shell size is 54mm ?
  1. Replacement wheelset for 2008 Monocog
    By rdaled in forum Singlespeed
    Last Post: 12-23-2014, 12:46 PM
  2. Replies: 12
    Last Post: 11-14-2013, 05:40 PM
  3. 2008 Stumpjumper Triad replacement
    By soccerfan in forum Specialized
    Last Post: 07-01-2012, 04:11 PM
  4. Seal Replacement on 2008 Fox 32 F120RL
    By flyinhawaiiandher in forum Shocks and Suspension
    Last Post: 04-08-2011, 11:25 AM
  5. Seal Replacement on 2008 Fox 32 F120RL
    By flyinhawaiiandher in forum General Discussion
    Last Post: 04-07-2011, 04:03 PM
