• 11-24-2014
    Hudnut
    '11 spearfish pivot bearing replacement
    on an 2011 spearfish the salsa site shows the lower bearing replacement as 6903-2rs. That number shows as a bearing with a 30mm diameter This is not correct according to my measurements. can someone direct me to the correct lower pivot bearings
  • 11-24-2014
    Hudnut
    never mind. I was able to clean the old bearings up enough to read that they are 6900-2rs.
  • 12-14-2014
    June Bug
    Just yesterday, someone who knows bearings and pivots strongly recommended getting bearings from Enduro Bearings.
    I'll be replacing the bearings on my 2013 Spearfish bottom pivot before my next ride.
    Check out their bearings offerings here.
