$20 XD freehub for Salsa hubs- Mtbr.com
Results 1 to 12 of 12
    Jul 2014
    If anyone needs a replacement XD driver for their Salsa hub like this one: XD Freehub Body | Parts & Accessories | Salsa Cycles
    Jenson has this Race Face XD freehub on clearance for $19.99, and I can confirm that it is identical to the Salsa freehub. Had the same date code and markings as mine and after checking with a micrometer everything including the spacers are the same. $100 cheaper than the Salsa hub.
    Race Face XD Freehub Driver > Components > Wheel Parts > Freehub Bodies | Jenson USA
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    Sep 2013
    Thanks for the tip! I just bought one as a spare...
    Sep 2014
    Does this also fit the 197 Salsa hubs found on the Blackborow and Ice Cream Truck?
    Oct 2016
    The secret is out, they just went up to $49!
    Jul 2014
    Quote Originally Posted by ETChipotle View Post
    Not sure- I've used them to convert 142mm and 177mm hubs, but I don't know if the 197mm hubs use the same style of driver. If you remove your driver and it has the tapered spacer and three pawl with a spring through the middle of each, then it likely should fit.
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    Sep 2013
    Need a replacement
    I am looking for an alternate to the Salsa freehub that I continually replace. my last one lasted 9 months. Same story, the bearings are falling out of it. Would like to find a way to just replace the bearings. but also replace the unit with something of higher quality.
    any guesses if this is the exact same size spec?
    SRAM XD Driver Freehub Body > Components > Wheel Parts > Freehub Bodies | Jenson USA
    Jul 2014
    Quote Originally Posted by backen View Post
    No that is a different style freehub. 4 pawl vs 3.
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Now up to $93 from Jenson...
    Are the Salsa hubs made by Formula?
    I'm trying to find an XD driver for my Formula fat bike hub and the Formula website is useless...
    Rolling on 29", 650b, 8.3" and 23mm
    Sep 2013
    Quote Originally Posted by 6thElement View Post
    Yes...Formula makes Salsa's hubs. Yes...Formula's site IS useless!
    Can anyone confirm this XD driver will fit on the Salsa (Formula) 197 fat hub? The Salsa website shows no part #. I want to convert my Ice Cream Truck to GX Eagle but don't want to buy a new hub.
    Quote Originally Posted by aminkman View Post
    Use the NX Eagle cassette. It works great with GX and you can use your existing hub and save money too.
    Jason
    Disclaimer: www.paramountfargo.com
    Thanks JAGI410, I ended up going with the Sunrace cassette. Also, I found out there was an aluminum and steel version. If you have a steel freehub the part # is: "Thanks for the email. You should be able to order one of these through your local bike shop. The part number on this XD Driver is FW4558." From QPP. Also from Surly:
    "Thanks for reaching out. Your local Surly dealer can order part# FW4558 from our distributor Quality Bike Products. Be sure to use the internal 16mm spacer and not the 23mm spacer!"
  1. Xd freehub for Ibis hubs?
    By Paul604 in forum Ibis
    Last Post: 05-15-2019, 02:14 PM
  2. hubs with steel freehub
    By adamantane in forum Wheels and Tires
    Last Post: 05-24-2015, 05:53 PM
  3. Budget / cheap hubs that can run XD freehub bodies
    By aybee in forum Wheels and Tires
    Last Post: 08-20-2014, 08:05 PM
  4. Stuck salsa muk 2 freehub body
    By Geist262 in forum Fat bikes
    Last Post: 01-03-2013, 03:17 PM
  5. Higher poe freehub for gravity hubs
    By Snowboarderdude in forum Motobecane
    Last Post: 08-19-2011, 07:25 PM
Members who have read this thread: 10
