Widest Tires? - 2019 Instinct- Mtbr.com
Results 1 to 18 of 18
    Reputation: mLeier's Avatar
    Oct 2017
    Hey All!
    I tried to read through the 2018 thread to find this answer but didn't come across it. Sorry if it has been asked and answered before.
    My husband really likes this bike and is considering purchasing it but after coming from 2.8" tires, he doesn't love how skinny the stock 2.3" tires on this bike are.
    Has anyone riding wider tires on this bike? How do you like it? What do you think the widest front and back tire that you could get on this bike would be? We would stick with the stock rims that are 30mm (I believe). Would love to be able to put 2.5" on the front and 2.4" on the back.
    Also, are the frames for the 2018's exactly the same as for the 2019's? Wondering if he get wider tires on the 2018's as well if we got a good deal on one of those instead of a 2019.
    Reputation: RMB-PM's Avatar
    Quote Originally Posted by mLeier View Post
    Hey All!
    You should be able to get at least 2.5" on the rear, possibly a lower profile 2.6" (Maxxis Rekon). As for the front, it's dependent on the fork, but you haven't changed it, 2.6" will fit.
    Director of Product
    Rocky Mountain Bicycles
    Aug 2017
    I currently run a 29x2.6 Hans Damphf on the front and a 29x2.6 Nobby Nic rear with no issues or worries about clearances. Both are mounted on 30mm interior width rims. Will post pics if i can find them
    Widest Tires?  - 2019 Instinct-instinct-sf.jpg My Instinct has 2.6 front and rear and is as wide as I'd go.
    Oct 2017
    Perfect! Thanks for all of the answers.
    Does anyone know if the 2018s would also fit 2.6 front and 2.5/2.6 on the rear?
    There's no need to fear.
    Reputation: Boofhead's Avatar
    You can also turn an Instinct into a Pipeline by running 27.5+ wheels. I'm pretty sure you can run those tyres up to 2.8".
    I believe the 2018 and 2019 Instinct frames are the same.
    contains quinine
    Reputation: Debaser's Avatar
    I've got a Pipeline with a set of both sized wheels. Currently set up with 29x2.6 Terravail Kennebecs.
    Take the long cut, we'll get there eventually.
    Aug 2017
    Showing the rear tire clearance with a 29X2.6 Nobby Nic inflated to 22psi on a 30mm id rim.
    internally 30mm? hmmm think the 2019 are 27mm which wouldn't be nice with 2.6"
    Aug 2017
    Yes. My bike has Santa Cruz Reserve 30s on it.
    To be completely honest, Im very happy with the 2.6 and it helps a ton with some of the loose and sandy sections that are all over my typical trails, thats pretty much the biggest thing though. You definitely feel the slower spin up with the additional mass rotating. My next set of shoes will be 2.4s.
    Sent from my iPad using Tapatalk Pro
    Mar 2019
    I have a 2018 Instinct and am currently running a 2.5" Maxxis Aggressor. No complaints at all.
    contains quinine
    Here's my Pipeline with 29x2.6 Terravail Kennebecs. The wheels are stock A50 Instinct wheels I bought from a friend.
    Attached Thumbnails Attached Thumbnails Widest Tires?  - 2019 Instinct-20190626_183304.jpg
    I have a 2018 which is the same frame as 2019. I run a Forekaster and Rekon 2.6 front and rear. Good clearance but that is the max I would go. Im using i29 carbon rims.
    My bike is actually a C70 Pipeline which is the same frame as the Instinct sans the removable fork to headset spacer. Its been setup as a 29er since day one.
    Jul 2019
    I just got a 2019 Instinct. I will be going 2.6 for winter.
    Can I ask you what the yeti who thing is on your bike, I have a 2019 instinct & im always get crap stuck between the frame & the rear triangle.
    Aug 2017
    The "Yeti who?" is a sticker I got from Camden and Parker (Rocky reps) from the last demo stop they did in Houston. Sadly I lost it last time I did a wash on the bike.
    The black part is a very slick bit of kit made by a fellow in Switzerland. It mounts in place of the blocks underneath the chain guide.
    https://www.facebook.com/pages/categ...7180596476332/
    Jul 2019
    Hey All!
    I believe the Instinct can handle 27.5+ tires. You should be able to fit 3" tires. Their diameter should be close to 29 tires and you get wider tires ... with some added weight.
    Aug 2017
    If you go that route, youll need the cup adapter to correct the geometry for the slight difference in diameter.
    The instinct is nearly the same bike as the pipeline. The frames are identical, only minor differences in trim out and 29 vs 27.5+
  1. Replies: 2
    Last Post: 01-23-2019, 07:06 AM
  2. 2019 Stumpjumper vs. RM Instinct
    By Freeflyer82 in forum 29er Bikes
    Last Post: 09-19-2018, 03:30 PM
  3. 2019 Instinct A70; why or why not?
    By Wish I Were Riding in forum Rocky Mountain
    Last Post: 08-08-2018, 12:10 AM
  4. Just picked up my RM Instinct 2019 A70 couple questions..
    By bonez3113 in forum Rocky Mountain
    Last Post: 08-01-2018, 11:59 AM
  5. Replies: 11
    Last Post: 11-30-2004, 12:49 AM
