Vertex 950 internal routing for dropper post?- Mtbr.com
Results 1 to 5 of 5
    Just purchased a 2017 RM Vertex 950. Does anyone know if this bike has internal routing for a dropper post?
    ups and downs
    If you run a 1x drivetrain you might be able to use the front derailleur internal cable routing for a dropper. It would likely need to be a Reverb with a hydraulic release as the routing through the BB would have some tight turns to get from the down tube to the seat tube.
    Its set up as a 2x10 right now. I guess ill have to externally route it if I decide to add one.
    Aug 2015
    I ran a internal cable dropper in the FD location. It was a pain around the BB but it worked. If you are running 2x you will have to strap it to your frame?
    Reputation: Chrissewanee's Avatar
    Jan 2017
    Old thread, but TS manage to pull it together?! Looking for the same update.
    Isn't the hole in the downtube to narrow for a whole (outer) cable?
    Grtz Chris
  1. Dropper post routing - internal or external?
    By j0hn in forum Components
    Last Post: 12-11-2016, 06:07 AM
  2. Following dropper post internal routing ?
    By Flat Again??? in forum Evil Bikes
    Last Post: 01-20-2016, 07:13 PM
  3. Replies: 1
    Last Post: 12-02-2015, 07:05 AM
  4. Internal routing dropper post on stumpy
    By Unforgiving in forum Specialized
    Last Post: 12-03-2013, 08:03 AM
  5. Internal dropper-post routing
    By Sweetwater Jones in forum Beginner's Corner
    Last Post: 11-10-2013, 08:22 PM
