Using XT cranks on 2016 RM Thunderbolt w/ stock bottom bracket- Mtbr.com
    Reputation: NeilJasper's Avatar
    Sep 2013
    I have a hardtail that has my XT 2x cranks and a Thunderbolt that is all stock and was wondering if I can just swap out the cranks without changing the bottom brackets of the bikes. Can anyone confirm?
    ups and downs
    It depends which Thunderbolt, as the Race Face Next and Turbine cranks use a 30mm spindle, if it's one of the models with Shimano or the Race Face Aeffect cranks they use the 24mm spindle BB and you can swap them out for the XT.
    If it's the Thunderbolt 710 with the FSA Gamma Drive cranks, you'd need to swap bottom brackets as those only have a 19mm spindle.
    Sep 2013
    Quote Originally Posted by rockyuphill View Post
    Crap, I have the 710 which has the Gamma drive cranks. I remember there was a product that converted press fit BB to threaded BB. Might that be the way to go or just change the current PFBB to a 24mm spindle?
    ups and downs
    Just change the BB to a Shimano or RF BB-92 press fit for a 24mm spindle. Both have decent reliability, the Shimano XT level BB-92 are not expensive.
    Shimano XT MT800 MTB Press Fit Bottom Bracket | Chain Reaction Cycles
    If you're switching from the 3x drivetrain to the 2x XT drivetrain you'll also need to change your front derailleur to get it to mate with the 2x chainrings and likely the shifter, as I don't think the Deore level 10 speed shifter had the 2/3 selector on the underside of the shifter
    2x10 XT E2 front derailleur with a big ring capacity of 38-40T and a 12T difference between small and big ring
    Shimano XT M785 E2-Type 2x10 Front Mech | Chain Reaction Cycles
    XT front shifter for 2 or 3 speed (you can buy just the front shifter)
    Shimano XT M780 10-Speed Trigger Shifter | Chain Reaction Cycles
  1. Replies: 5
    Last Post: 07-26-2016, 05:51 PM
  2. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  3. Stock 2016 Pike vs Stock 2016 Float 34 for 250+ Rider
    By MaddSquirrel in forum Shocks and Suspension
    Last Post: 01-29-2016, 02:11 PM
  4. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  5. New-old stock: 1992 Suntour SL bottom bracket /w loose bearings
    By brenton in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-19-2013, 02:09 PM
