Under BB cable routing issues?- Mtbr.com
Results 1 to 7 of 7
    The new Instinct is on my short list to replace my Ripley. I've noticed RM uses under the bb cable routing on their bikes. Seems less than ideal and asking for snagged cables in tech terrain. Is this actually a problem in the real world?
    President of the Internet
    Reputation: Widgeontrail's Avatar
    Mar 2006
    Quote Originally Posted by ripn View Post
    Nope. Never. I've had a few other minor issues. But never snagged it on anything.
    When my Instinct was 2x I once accidentally twisted the shift cables around each other inside the down tube which caused shifting problems, but that was user error (i'm 1x now anyways).
    The only other problem is that my dropper is full housing and will often have the excess housing fall from the handlebars to under the BB, if that makes sense. I have to pull it back up. Its easily remedied with a zip tie. I just keep forgetting to put one on!
    Sometimes you eat the trail, sometimes the trail eats you.
    Thinking of buying a home?
    http://Search-Sacramento-Homes.com
    Total Goober
    I severed my brake cable when I rolled a rock that I should have jumped, but that is such a small area to hit perfectly that I don't see it being an issue again. My cables collect weeds and junk when I go off-trail, but no other problems.
    FYI, that was on an Altitude.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    ups and downs
    You're much more likely to tear a pedal or chainring off on a rock than a cable or hose, in normal use they don't hang down anywhere near as far as the chainring.
    Cool. Thanks for the input.
    Guest
    I used to think it would wear fast, being exposed to front tire crud, but I've had several and not one issue yet. There are bikes where full length housings make sense, but I've not had an issue with anything related to the bb routing.
    Sep 2014
    Other brands have had the cables exit under the BB for many years.
    If you are truly worried grab an iscg05 bash guard and mount it up. That'll help protect your cables a bit but more importantly protect your chain ring and bottom bracket
  1. Downtube cable routing, any issues?
    By aflax in forum General Discussion
    Last Post: 11-20-2014, 12:00 PM
  2. Issues with Internal Cable Routing
    By Constantinos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2013, 09:16 AM
  3. Internal cable routing as it relates to cable housing bend?
    By Drew Diller in forum Frame Building
    Last Post: 10-10-2012, 07:44 AM
  4. new 5 spot cable routing.issues?
    By KgB in forum Turner
    Last Post: 08-03-2012, 05:53 AM
  5. Help: Mach 5.7 Rear Swingarm Cable Routing Issues
    By Rei_Ikari in forum Pivot Cycles
    Last Post: 11-23-2011, 07:01 PM
