Turner v Rocky Mountain- Mtbr.com
Results 1 to 5 of 5
    Reputation: CragRat's Avatar
    Feb 2005
    Hi currently riding a Turner Burner 27.5....been a Turner rider since 2005 but really liking the look of the new Instinct and Thunderbolt...and fancy a change.
    Does anyone have any experience comparing the two brands Particularly DW link v Rockys Smoothlink.
    I guess the instinct is = to turner czar and the turner burner = thunderbolt .
    Really interested i how they compare in particular climbing as lots of folk say DW is the holy grail..
    Thanks CR
    Also anyone know the bb hieght of the 19 standard instinct as i can only ses bbdrop listed.
    Ta
    ups and downs
    The reference for the Instinct BB drop is the radius of a 29" wheel, so right around 370mm (14-9/16") based on a 2.2" tire.
    One of the biggest differences between Rocky's SmoothLink and the linkage type suspensions (DW Link, VPP and Maestro) is the amount of chain growth and pedal kickback with suspension travel, the Rocky has a moderate amount of chain growth and not much pedal kickback with increasing travel, where the linkage type suspensions have more chain growth and pedal kickback.
    SmoothLink also has more linear anti-squat where the linkage type suspensions have an N shaped anti-squat curve with the minimum mid point around the recommended sag point, so pedal induced chain tension helps keep the suspension balanced around the sag. The Smoothlink doesn't rely on pedal induced chain tension to hold it around the sag position, there's less anti-squat with increasing rear wheel travel. This Linkage plot of a Pivot 5.5 anti-squat has the same characteristic as the Turner DW link. The Thunderbolt anti-squat curve is typical of all the current SmoothLink suspensions on the Instinct/Thunderbolt/Altitude/Pipeline, Slayer frames.
    Attached Thumbnails Attached Thumbnails Turner v Rocky Mountain-pivot-mach-5.5-carbon_anti-squat.jpg
    Feb 2005
    Thankyou....so will that mean the smoothlink bikes will be more wallowy feeling and sag lower into its travel during climbing
    ups and downs
    The Smoothlink bikes don't need the chain tension to hold them at that sag position so they pedal very... smoothly. You just don't get any sense that the pedaling is influencing the suspension movement, it leaves the suspension able to react to the terrain, so it is active but not mushy.
    Feb 2005
    Ok...mm..so what holds the smoothlink at sag point..
    Rocky say they have increased anti squat this year....how do they do that keeping what appears to be the same pivot positions...
  1. Budget Rocky Fatbike - Rocky Mountain Blizzard - 10
    By tbonegreen in forum Fat bikes
    Last Post: 12-22-2017, 11:22 PM
  2. 2007 Rocky Mountain Element Team vs Turner Nitrous?
    By Cheers! in forum Weight Weenies
    Last Post: 05-25-2007, 07:48 PM
  3. Canadian Devinci / Rocky Mountain vs Turner
    By gecho4 in forum Canadian Bikes
    Last Post: 02-22-2006, 07:11 PM
  4. Clyde friendly Rocky Mountain ETSX-70/local Rocky dealer review
    By glorth2 in forum Clydesdales/Tall Riders
    Last Post: 07-07-2005, 10:35 AM
