Rocky Mountain Microdrive 28T BCD?- Mtbr.com
Results 1 to 2 of 2
    Jun 2019
    We recently bought a Growler Jr 24 for my daughter which has the 155mm cranks and 28T front chain ring. My daughter is short, and I need to swap out the cranks for shorter, probably 130mm or 127mm cranks depending on what I can find.
    What is the BCD of the Microdrive cranks? I measured with calipers and they look to be 76mm BCD but I want to make sure I'm not missing something.
    Anyone know if it ISO taper or JIS taper? It is a seal cartridge bearing bottom bracket.
    Thanks.
    ups and downs
    The tricky thing is that the four bolts aren't equally spaced, the space between the close pair is about 52mm and the other two are about 56mm apart. So they are on a 76mm BCD, but not 4 equally spaced holes.
    You're likely going to end up replacing the cranks, chainring and BB to get what you want.
  1. Replies: 0
    Last Post: 06-27-2016, 05:56 PM
  2. Anyone running a 64 BCD 28t or 26t chainring?
    By davesupra in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2014, 12:00 PM
  3. Run a 28t 1x10 with 104 BCD Crank
    By lhovden in forum Fat bikes
    Last Post: 09-11-2014, 07:30 AM
  4. Question on 104-BCD 39t vs 120-BCD 39t?
    By Blk02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-03-2012, 12:14 PM
  5. 2x9: 27 (BCD 74) in middle and 39 (BCD 130) in outer?
    By MikelDuke in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2011, 08:43 AM
Members who have read this thread: 18
