Rear shock removal- Mtbr.com
Results 1 to 5 of 5
    Mar 2012
    Rear shock removal/install
    Hello All,
    I posted this in the shock forum but thought I might get more feedback on here.
    I purchased a Fox DPX2 to replace the current DPS on my 2016 Rocky Mountain Instinct 950.
    I thought it would be pretty easy to swap out but for the life of me I canít figure out how to remove the old one from the frame. I removed the bolt that attaches to the rear triangle and thought it would just slip/pop out. Is there a technique to this?
    Any help would be appreciated.
    tia
    ups and downs
    You'll need to remove the bolts that attach the seat stays to the swing link and drop the seat stays down off the swing link, then you'll be able to get the shock out.
    It's much the same process as used for servicing the Element in this video
    Rocky Mountain Element MSL Service Video | Rocky Mountain Bicycles
    Mar 2012
    Thanks rockyuphill, that worked like a charm.
    I assume I torque the bolts the same as in the video too?
    ups and downs
    Here's the torque specs
    Mar 2012
    Ok, I finally got some time to install the dpx2 today and am having difficulties getting the "metal sleeves" into the shock mounting holes. I did not swap the white pieces as they were already installed.
    I was told by fox and my lbs that it would be a straight swap of hardware since the stock dock was also a fox (DPS).
    Does this mean they're wrong and I need new hardware or am I doing something incorrectly and there's some sort of technique?
    Attached Thumbnails Attached Thumbnails Rear shock removal-img_20180326_132325.jpg
  1. Kona process rear shock removal
    By Makarmtb in forum Kona
    Last Post: 03-15-2015, 04:34 AM
  2. rear shock removal
    By nate. in forum General Discussion
    Last Post: 01-09-2014, 03:18 PM
  3. HD rear shock hardware /reducer removal?
    By fuenstock in forum Ibis
    Last Post: 05-09-2012, 04:33 PM
  4. Replies: 2
    Last Post: 03-07-2012, 01:35 PM
  5. Altitude 50 RSL Rear Shock removal question
    By skrap1r0n in forum Rocky Mountain
    Last Post: 06-15-2011, 09:35 AM
Members who have read this thread: 10
