Lockdown project: 01 Slayer- Mtbr.com
Results 1 to 2 of 2
    Just picked up a project to build up for a friends 13yo son. I was going a bit crazy at home with after finishing my other bike projects.
    This one at some point I'm guessing was owned be some tweakers.
    Some issues I'm working on:
    * Marzocchi QR20 axle was stripped and fitted into a regular hub with an extra bearing race as a filler
    *10 speed shifter, 9 speed derailluer & 8 speed cassette
    *Mismatched brakes & the wrong adapter for the QR20 fork.
    *Front wheel wasn't a 20mm axle. Already lined up a used Mavic DeeMax
    I've got most replacement parts coming soon, the QR20 axle will be the biggest project as I have to fab up a spacer to fit in the 20mm axle. Although I've got some 20mm OD 15mm ID aluminum tubing coming that I think should do the trick.
    On the to do list:
    New Igus bushings
    Full cables & housing
    new cassette (9 speed)
    new rear shifter
    Service the forks
    Service the rear shock
    bearings service & true rear wheel
    Try and make a 20mm QR axle that works
    Swap out rotors
    Find a new front brake.
    Grips
    Service pedals
    Should keep me busy for a few weeks. Hopefully
    Attached Thumbnails Attached Thumbnails Lockdown project: 01 Slayer-1.jpg
    Lockdown project: 01 Slayer-20200406_113640.jpg
    Lockdown project: 01 Slayer-deemax1.jpg
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2019 Kona Process 153 CR 29
    Last night I had a chance to start making a bit of progress
    Fresh proper oil for the Z1 DO. Old oil wasn't terrible but it was low. Poured in some Glden Spectro 125/150 (7.5w) stock marz oil. 65mm depth from top of threads springs removed.
    Noticed some play in the bushings behind the BB. Struggled a bit to remove one of the bolts. There is a threaded bolt on the backside of that bushing. I used a water bottle cage bolt to keep the axle/insert from spinning. Apparently there is a hole drilled in it, proper way is to spin the stuck bolt/insert and place a 3mm allen key in the hole to keep it all from spinning.
    I measured the bushings. Waiting to hear back from RM if they have bushings, otherwise I'll be getting some from Igus. Measured 16mm OD, 14mm ID, 17mm width. Igus flanged DU bushing.
    https://www.igus.com/product/66
    Attached Thumbnails Attached Thumbnails Lockdown project: 01 Slayer-bushing1.jpg
    Lockdown project: 01 Slayer-bushing2.jpg
    83 Ritchey Everest
  1. Shimano Deore rear derailleur: cable lockdown positioning?
    By urbsuburb2017 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-27-2019, 08:44 PM
  2. Pisgah lockdown
    By mikeridesabike in forum North & South Carolina
    Last Post: 07-31-2017, 06:00 PM
  3. Stiffest 100-130mm w lockdown option
    By rogueturtle in forum Shocks and Suspension
    Last Post: 08-11-2006, 12:10 PM
  4. GT Lockdown and bar ends
    By capnstem in forum GT
    Last Post: 05-25-2006, 11:56 AM
Members who have read this thread: 14
