Instinct rear quick release?- Mtbr.com
Results 1 to 5 of 5
    Sep 2018
    Hi, i'm keen to see if anyone has swapped to a rear quick release and if you did what one have you used.
    I have two wheel sets, some DT Swiss wheels I use on the weekends and the stock wheels I use with fast tires to ride 20km to work every day with. What this has done over 6 months is warn the anodizing off the axle thread making it start to grab on the thread no matter what type or how much grease is used.
    I think in this case a quick release may be a good idea.
    A Shimano AX-MT700 looks like it should fit? Looks the same length(172mm) and the same thread.
    Thanks.
    Bike RM Instinct, Lives In Whangarei, New Zealand.
    Reputation: RMB-PM's Avatar
    You can def use Shimano SM-AX56 / 76. Haven't tested the MT700, but looks very similar. The only open question is whether the diameter around the lever fits inside the pocket on the frame.
    But if you want to be absolutely certain look for a 56 or 76 series axle.
    Director of Product
    Rocky Mountain Bicycles
    Sep 2018
    Cool thanks. The head size looks a bit smaller on the SM-AX56 / 76 at about 20mm so the same as stock.
    The stuck length is 172mm and the SM-AX56 / 76 comes in 171mm and 177mm. Looking at the bike 175mm is the longest that could be used so it looks like the 171mm is the go.
    Thanks.
    171mm is correct
    Director of Product
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Thrill Bikers Unite!
  1. quick caps quick release wheel locks?
    By titus in forum Wheels and Tires
    Last Post: 05-31-2016, 09:42 AM
  2. 2014 Instinct 950MSL - Rear Quick Release Issue
    By shawneeboy in forum Rocky Mountain
    Last Post: 05-21-2015, 07:36 AM
  3. Manitou Mavel Comp 9mm quick through bolt quick release
    By MBTStuff in forum 29er Components
    Last Post: 06-14-2014, 07:15 PM
  4. Replies: 3
    Last Post: 04-28-2014, 01:20 PM
  5. Making a quick release, a REAL quick release! Help!
    By metomeya in forum Wheels and Tires
    Last Post: 10-11-2005, 09:40 AM
Members who have read this thread: 25
