IGUS bushing size for element and altitude- Mtbr.com
Results 1 to 5 of 5
    Can anyone give me the specs for the IGUS bushings for an altitude 2009-2010 and/or element 1997-2003. On the rocky website they look like they could be the same size as the slayer 2011 bushings.
    ups and downs
    I doubt that many people are in a position to have them all laid out in front of them to take dimensions off them.
    It does look like there is some similarity in the rear seat stay bushings of the sets you described.
    Element 1997-2003
    Altitude 2009-2010
    Slayer 2011-2014
    Thanks rockyuphill. Looking at those pics now, the larger bushings look a bit smaller than the slayers.
    I've got a copy of the rmb tech manual for 2011-2012, (think I got the link from one of your posts) do you know of any previous tech manuals that are available.
    ups and downs
    Bikeaction.de has tech manuals going back to 2006. Some are in German but that's what Google Translate is for.
    Rocky Mountain
    I think the main pivot bushings will be similar when they use the same 12mm diameter of pivot axle, but the length could be different by a few millimetres.
    You can at least compare part numbers for the Igus bushings from 2006-2014
    Rockyuphill you rock! Thanks, will check it out.
  1. What Bushing Size?
    By bemmis in forum Beginner's Corner
    Last Post: 04-06-2014, 11:46 AM
  2. 2010 RSL altitude rear triangle bushing
    By 1362 in forum Rocky Mountain
    Last Post: 02-25-2014, 10:03 PM
  3. DMR V12 bushing size
    By DimitrisCSD in forum All Mountain
    Last Post: 10-08-2012, 08:27 AM
  4. Replies: 19
    Last Post: 02-08-2012, 12:35 AM
  5. Element vs. Altitude vs....... Slayer?
    By RockyRiderRay in forum Rocky Mountain
    Last Post: 06-14-2011, 12:20 AM
