Grease/grease gun- Mtbr.com
Results 1 to 5 of 5
    Mar 2012
    Grease/grease gun
    Hey everyone,
    Iím starting to do some maintenance on my Instinct for the coming season but need to get a grease gun/grease for the bc2 pivots.
    I was going to grab the one RM sells on their site but itís way too pricy so Iím looking for alternatives. The dualco looks the same but with a short tip. Itís a little cheaper but still..........
    Will the park tool gg-1 work? Is there another type of grease that can be used that is as good as bel-ray?
    tia
    ups and downs
    Mar 2012
    Thanks rocky. Whatís your take on the park gun? Is it a cheaper version of the dualco?
    ups and downs
    I suspect a sizable number of these all come from the same factory somewhere.
    Aug 2017
    I just picked up the RM one, but the Dualco looks absolutely identical to it (except for the shorter nozzle, and the RM one having a polished cap). The Park Tool cap is different from RM and Dualco (no threaded nut by the spring and it has a second threaded insert underneath so you can attach it directly to a tube of grease if you want). I'm not sure if the shorter nozzle would be an issue. I probably could have saved money with the other two options, but didn't want to risk it not fitting.
    2018 RMB Element Carbon (custom)
    2017 RMB Element 950 MSL
    1997 RMB Equipe
  1. Grease and grease gun for Zerk fittings
    By 5k bike 50cent legs in forum Santa Cruz
    Last Post: 09-12-2017, 01:28 PM
  2. Turner grease and grease gun
    By turnerbikes in forum Turner
    Last Post: 02-07-2015, 10:25 PM
  3. Grease Tube Theads Broke off in Grease Gun
    By kai_ski in forum Tooltime
    Last Post: 02-21-2014, 05:22 PM
  4. Grease gun and grease recommendation
    By wonny in forum Intense
    Last Post: 10-17-2012, 11:35 PM
  5. Manitou grease gun + other brand of grease?
    By Entrenador in forum Tooltime
    Last Post: 10-19-2007, 10:55 AM
