Excessive Instinct BC chain slap noise- Mtbr.com
Results 1 to 8 of 8
    Dec 2019
    I have a 2020 Instinct BC70 and love it. I have noticed excessive noise from the drivetrain with chain slap. Has anyone done anything to reduce the noise successfuilly? So sad the NZ summer will be over as this bike has been a blast on the dry trails.
    Sep 2018
    My ones a 2018 but I super glued small triangle foam bits to the chain stay and its worked well. Not the best pic but you can just see them.
    Bike RM Instinct, Lives In Whangarei, New Zealand.
    ups and downs
    You might be able to crank the clutch tension up a bit more on the rear derailleur and keep the chain under control. Pages 27/28/29 in this manual
    https://si.shimano.com/pdfs/dm/DM-MARD001-02-ENG.pdf
    This might might be what you're looking for https://stfubike.com/
    Aug 2013
    I'll just add that many bikes come with chains that could lose a few links from the factory. Many shops don't shorten them. I've never found my instinct particular loud.
    Sep 2013
    I have had my instinct on 4 rides now and I've noticed the same thing. I think the STFU Bike pieces don't have enough clearance as their site says you need 8mm of clearance between the bottom of the chain and the stay to work. Measuring mine with the E13 11 speed cassette right now, I'm at 6 to 7mm with a 32T ring up front. I'm about to put on a sram eagle setup though and maybe having a 10t vs a 9t will somehow make the difference to get the clearance I would need.
    There is a "ribbed" chainstay protector on Rocky's site but it is sold out at the moment. I emailed them over a week asking when it would be back in stock and have yet to get any answer back. Here is the link:
    https://shop.bikes.com/collections/i...-2020-instinct
    Sep 2013
    Also perhaps this is an option. This photo is from Melamed's bike from a OneUp promo video and photo shoot. Looks like some mastic tape with what appears to be knobs from a tire glued on to it.
    Reputation: sprocketjockey9's Avatar
    Mine has been a bit noisy, my clutch leaves a lot to be desired (apparently early Shimano XT's have an issue), but I put 2 of these on my chain stay and seems to be much quieter
    https://smile.amazon.com/ENLEE-Cycli...s%2C196&sr=8-5
  1. Instinct knocking noise (no, it's not chain slap)
    By Boover in forum Rocky Mountain
    Last Post: 03-25-2019, 01:18 AM
  2. Slash excessive chain slap?
    By traditiionalist in forum Trek
    Last Post: 09-28-2018, 07:57 AM
  3. Excessive chain slap with Shimano Acera rear derailler....something I can fix?
    By TeaQue in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-05-2013, 06:23 PM
  4. Excessive chain slap noise with new 2X10 setup
    By zuuds in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-24-2012, 03:13 PM
  5. Excessive chain slap?
    By jbl_91762 in forum Beginner's Corner
    Last Post: 09-01-2012, 10:09 PM
Members who have read this thread: 34
