Element 2017 pedal strikes- Mtbr.com
Results 1 to 7 of 7
    MJ1
    MJ1 is offline
    I have an awesome 2017 Element but I suffer from pedal strikes. I'm in the neutral position and I have 170mm cranks. I also installed a 10mm spacer in the lower headset to help. Should I try steep setting? Also, have a 120 fork.
    ups and downs
    The steepest setting will give you 5mm more BB height.
    ups and downs
    What sag are you running in the fork and shock? Have you confirmed the pressures this season?
    I had a similar situation with my 2011 Element at the start of the season, the shock had lost about 20% of the air over the winter so I was at something like 40% sag.
    Sep 2012
    What is your sag % ?
    MJ1
    MJ1 is offline
    Sag
    Quote Originally Posted by Nick_A View Post
    Great question! I had my bike serviced about 5 months ago and they worked on my pivots. They must have changed air pressure in rear shock and when I got it back to normal I had much less pedal strikes. Lesson learned....check pressure! But sadly, at least according to my Shockwiz, I'm right where I should be and still get 2-3 strikes per ride. It could be because I'm coming off a hardtail and I am used to pedaling through corners more so it could just be "habit". I'm going to try the steep setting and see how that goes.
    Thanks for everyone's comments.
    Sep 2012
    Quote Originally Posted by MJ1 View Post
    Element feels pretty good at 25-30% sag...so 10-11mm...maybe a hair more if you need it more plush. But coming from a hardtail 25-30% should feel good. Also, check your pressure/sag often.
    MJ1
    MJ1 is offline
    Thanks again for the suggestions. I have my rear shock setup on the firm side now and flipped the chip to the Aggressive setting. Bike feels amazing now on the trails, it felt great before but I think this geometry suits me better. And no more pedal strikes!!
    I need to re-attach my ShockWiz just to see if the geometry changes affected anything there but I feel great on the bike so maybe just leave it alone for now.
  1. Which bike will produce less bottom bracket strikes - pedal strikes
    By TheNatureBoy in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 05-02-2019, 02:23 PM
  2. 2017 Yeti ASR vs 2017 Rocky Mountain Element.
    By Ksanman in forum General Discussion
    Last Post: 03-13-2017, 08:32 AM
  3. Pedal strikes and chainring/bashguard strikes = frame damage?
    By Varaxis in forum Bike and Frame discussion
    Last Post: 09-25-2013, 12:45 AM
  4. Replies: 5
    Last Post: 06-24-2011, 06:24 AM
  5. Replies: 11
    Last Post: 02-21-2011, 07:25 PM
Members who have read this thread: 38
