Converted my 2016 Thunderbolt to 1x- Mtbr.com
Results 1 to 8 of 8
    Sep 2019
    Decided to convert my bike to a one by and learn more about bike maintenance at the same time.
    Started with lots of research on gearing and chainlines and things seems to have worked out. Didnít want to loose any lower gears, actually wanted to be able to go a little lower.
    Ended up ordering:
    - Race Face 30T Narrow Wide (104BCD)
    - Sun Race MX3 10 speed 11-46T Cassette
    - Goatlink 10 speed derailleur extender
    - Longer b screw
    The swap was fairly straight forward and with just one slightly stuck chainring bolt it came part and cleaned up. Old big ring was missing a couple teeth
    After assembly I realized that the size of the cassette big ring (and actually the second last too) was too tight I found out a out the GoatLink and managed to find one in town at a local bike store. Still found after that was installed that it was slight right on the large 46T ring. Found a longer b screw screw courtesy of a another local bike shop and now it works very well.
    First ride out and it held up nice. Did find the b screw loosened out a bit so added a little blue lock tight.
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by juched View Post
    Ended up ordering:
    - Longer b screw
    Lengthen your chain! Holy shit.
    Fatbike, XC bike, Gravel Bike....
    Sep 2019
    This is it on the smallest gear. Canít really go to much longer. But will do.
    ups and downs
    Page 12 of this Shimano manual shows how to size the chain properly
    https://si.shimano.com/pdfs/dm/DM-RD0004-09-ENG.pdf
    Apr 2014
    Seeing this is 1x. you want your derailleur to have zero chain tension on it in the smallest gear. Run the chain thru and connect it so it has a slight bit of tension on the cage.
    I did this for my 1x11 10-46 and it works flawlessly and mine is a hardtail. If you bottomed in that big ring it would be nasty.
    Sep 2019
    Quote Originally Posted by solarplex View Post
    Thank you.
    Some guy
    I did something very similar on my '14 Thunderbolt. Ordered a RaceFace 30T Narrow-wide chain ring, a new clutch derailleur and a new chain and cassette. I stuck with a standard 11-34 10sp cassette but I have never wanted for range in riding Ontario/Vermont trails. As far as I am concerned no mountain bike should ever have a front derailleur any more.
    Sep 2019
    Got a new chain. While the measurement from the old chain matched what a normal sizing asks for (plus two links) from the pic you can see it looks short.
    So I tried 4 links but on the smallest cog the chain hung loose slightly. Removed one more link and now it seems tight enough.
    Shifting with a new chain is much more spot on. I should have never reused the old chain, even though my chain stretch tool didnít show it was worn out. Glad to have leaned a lot doing this conversion.
  1. 2016 Thunderbolt Rear Shock Options
    By Rocky Mtn in forum Rocky Mountain
    Last Post: 11-17-2019, 03:53 PM
  2. Replies: 3
    Last Post: 10-19-2017, 06:48 AM
  3. 2016 Thunderbolt rear suspension harsh?
    By Niko in forum Rocky Mountain
    Last Post: 09-14-2017, 04:20 PM
  4. Replies: 5
    Last Post: 07-26-2016, 05:51 PM
  5. Replies: 4
    Last Post: 08-08-2014, 02:46 PM
