Convert 2017 Vertex 950 to 12x142 rear thru axle- Mtbr.com
Results 1 to 6 of 6
    Bought a set of wheels with hope hubs and didnt plan the rear axle correctly. The hubs have a 12x142 thru axle and my bike is setup for a regular qr . Is it possible to convert the bike to a 12x142 thru axle? Id prefer doing that than buying the parts to convert the hubs to a QR.
    ups and downs
    The frame can't be converted, the 142x12 dropouts are entirely different than the 135mm QR.
    The ideal thing would be to convert the Hope rear hub to use a 135x10mm thru axle and use a DT Swiss RWS thru axle. Much sturdier than a conventional QR.
    Gotcha. Im just getting back into MTB after a long hiatus. All of these standards are dizzying, lol!
    Once I convert the hub, its just a simple as getting the correct axle? Nothing else needs done?
    ups and downs
    With the 10mm axle conversion, it behaves just like a standard QR hub, just stiffer and easier to tighten up, with no chance of a QR skewer opening up. There's only one length of 10mm RWS as well.
    https://www.dtswiss.com/en/products/hubs-rws/rws/10-mm/
    Excellent, thank you for the help! I have one of these on order! Just need to order the end caps for my hubs now.
    I remember back in the day when everything was pretty well a standard size. Now there doesnt really seem to be a standard.
    ups and downs
    Standards are like points, a point in every direction is the same as no point at all. Bike hardware standards are becoming like that. At some point, there's no point.
  1. 2017 Vertex 950 seatpost clamp size
    By jreed3 in forum Rocky Mountain
    Last Post: 10-03-2017, 02:59 PM
  2. 12x142 Closed Convert Axle on Superfly HT
    By mtnbkrdr98 in forum Trek
    Last Post: 05-02-2015, 03:19 PM
  3. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  4. Roscoe 3 with 12x142 reAr thru axle
    By vwsb74 in forum Trek
    Last Post: 10-04-2012, 04:55 PM
  5. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
