2018 Rocky Mountain Altitude weird wear/ride 9- Mtbr.com
Results 1 to 12 of 12
    Apr 2015
    I have some weird wear on my altitude. I haven't changed the ride 9 chip, ever. Tho I'm considering it at this point as I've taken time to get used to the position it came in.
    Now looking at all available postions in this guide, (http://www.bikes.com/sites/default/f...itude_EN_0.pdf) I'm noticing that the configuration my bike is currently in, is not the same as any of the options listed in the guide.... what's going on here? How is it even possible.
    Furthermore, see that grey area to the left of the ride 9 chip, that looks like completely not normal wear to me, or is this normal / to be expected? I can't find another bike online that has the same wear.
    Help!! (yes, the bike needs to be cleaned!)
    2018 Rocky Mountain Altitude weird wear/ride 9-img_0815.jpg
    2018 RM Altitude Carbon 90
    2017 All City Macho King
    2016 Salsa Marrakesh
    Yuba Mundo
    2016 RSD Mayor
    2012 Stumpjumper
    Apr 2015
    Good grief, why'd the photo post upside down... look to right of shock now instead of left.
    THIS IS AN UPSIDE DOWN IMAGE! ... what gives!!
    Yuba Mundo
    2016 RSD Mayor
    2012 Stumpjumper
    Pos rep makes me sad
    Reputation: dv8zen's Avatar
    Nov 2017
    mtbr doesn't do well recognizing orientation in cellphone pics.
    By grey area, do you mean this one?
    2018 Rocky Mountain Altitude weird wear/ride 9-mw4yrwt.jpg
    You're in the center-neutral position. Only thing that matters is the bolt location, considering there's multiple ways to get to that position.
    Also, bikes hate being washed as much as they hate not being ridden, in regards to long term health.
    Hope I didn't say anything that would cause you to over-react or dramatize things further.
    Tell me when I'm wrong. Neg rep me. I will appreciate it, even if you don't explain why I'm wrong.
    Apr 2015
    that's the one! hmm so, that must be ... normal then? hard to tell what kind of material it is by hand, didn't have magnet on me.
    Yuba Mundo
    2016 RSD Mayor
    2012 Stumpjumper
    Nov 2017
    Looks like it's just unpainted/nude "carbon" (thermoset carbon fiber reinforced plastic). I presume that the thickness of the paint would've made that part interfere with movement, so they masked it off.
    2018 Rocky Mountain Altitude weird wear/ride 9-p.vitalmtb.comtemp_photos2175full_dsc2603_221477-c0a9030a099e4078ac9cb0b7b917341c98a9fb40.jpg
    Is this enough evidence for you to consider it normal?
    Apr 2015
    You bet man, thank you!
    What’s your thoughts on the ride 9 position?
    Nov 2017
    I left my RM in the center position for everyday riding, but had the large chip oriented so it'd be more convenient to switch it to slack/low (pos 1) for possible bike park days (which never happened). You're already set exactly how I described.
    ride
    Reputation: ignazjr's Avatar
    Shouldn't even be close enough to where it'd rub. Frames are full paint from the factory. There should be a spacer between the frame and the linkage, easily visible. Take the shock out (or just out of the top mount) and cycle the suspension. Does it rub? If there is a spacer there and it is still rubbing, it could be a dead bearing.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    Reputation: RMB-PM's Avatar
    Hi, that isn't rub, that's where the paint is masked off to avoid interference. It shows the sweep of the link through full compression.
    Quote Originally Posted by nilbert View Post
    Director of Product
    Rocky Mountain Bicycles
    Apr 2015
    Thanks Rocky! I appreciate your following up. I couldn't actually figure out how it could have been rubbing, perhaps a moment of panic on my part. Nice to know all the good folks here, including you, has our backs!
    Yuba Mundo
    2016 RSD Mayor
    2012 Stumpjumper
    Nov 2017
    Is that particular paint finish thicker than the other colors?
    Quote Originally Posted by dv8zen View Post
    As a matter of fact it is... Note near the dropout the 2 tone paint: bottom is blue. So the whole thing is painted blue, masked off, then painted red over top.
    Director of Product
  1. Replies: 12
    Last Post: 06-03-2020, 09:00 PM
  2. Replies: 1
    Last Post: 12-28-2017, 04:47 PM
  3. 2018 Rocky Altitude Carbon 90 coming when?
    By nilbert in forum Rocky Mountain
    Last Post: 06-19-2017, 09:36 AM
  4. Is this weird? Yeah, it's weird.
    By Finch Platte in forum Off Camber (off topic)
    Last Post: 04-09-2016, 04:59 AM
  5. Replies: 6
    Last Post: 10-26-2012, 06:21 PM
