2018 headset bearings (Thunderbolt)- Mtbr.com
Results 1 to 5 of 5
    Mar 2018
    Who knows the specs/link to headset bearings for the new Carbon 2018 Thunderbolts? They should be the same as the Altitude as well. I donít wanna spend $70 to get a whole new headset, when all I need is just the lower bearing. Itís a FSA ORBIT no. 57e that comes with the bike.
    Any help is appreciated!
    ups and downs
    The lower bearing is an MR019, 40mm ID, 51.8mm OD and 7.5mm tall, with a 36deg inner chamfer and 45 degree outer chamfer. They are still fairly hard to find as a bearing by itself.
    https://www.kineticbikebearings.com/...t-bearing.html
    Mar 2018
    [QUOTE=rockyuphill;13819857]The lower bearing is an MR019, 40mm ID, 51.8mm OD and 7.5mm tall, with a 36deg inner chamfer and 45 degree outer chamfer. They are still fairly hard to find as a bearing by itself.
    Thanks a bunch! Do you have the info on the upper bearing as well awesome sir?
    ups and downs
    The top bearing is an MR040 (873/DJ-RS)
    https://shop.fullspeedahead.com/en/b...-1-1-8-steerer
    Mar 2018
    THANK YOU so much! Money is real tight for me at the moment and this is going to help me keep riding
    You made my day 🙌
  1. Thunderbolt Bearings
    By afraid in forum Rocky Mountain
    Last Post: 07-15-2019, 04:39 PM
  2. 2018 Carbon Thunderbolt!
    By Ridingandsmiling in forum Rocky Mountain
    Last Post: 01-15-2019, 04:08 PM
  3. Replies: 5
    Last Post: 05-24-2018, 04:19 AM
  4. 2018 Pike OR 2018 Push Fox 34 Factory?
    By almazing in forum Shocks and Suspension
    Last Post: 01-25-2018, 12:35 PM
  5. 2018 Nomad vs 2018 V10
    By cobrakillerta in forum Santa Cruz
    Last Post: 10-04-2017, 06:26 PM
