2011 Flatline Pro Bottom Bracket and Tool- Mtbr.com
Results 1 to 10 of 10
    KulAdventures
    Reputation: alexk243's Avatar
    So I have a 2011 RM Flatline Pro and I need to replace or repair something in the bottom bracket. I have a lot of creaking while pedaling. I cant seem to find the correct bottom bracket or the correct tool to remove the one I have to check it out. Any advice? What bottom bracket do they use? Crankset?
    Also is there a tip to removing the crankset on these? Struggling with that also.
    I got this tool: https://amzn.to/2I3UeaL but it doesn't work... too small
    ups and downs
    The 2011 Flatline Pro was shipped with a Race Face Respond X-Type BB which is the same tool interface as the Shimano Hollowtech II, so that tool you've linked should work unless the crank and BB have been changed over the past 7 years. Have you owned the bike from new?
    If the BB cups don't look like this, it would be helpful to post a picture of what you have
    KulAdventures
    I have not owned the bike from new. Got it in very used shape. So the tool I had did work after all... not sure what I was doing wrong. I got the BB out and it seems fine...
    Seems that the cranking noise is from where the pedals mount to the crank. Its a weird design that I have never seen before. The pedals are new and fine, but the bolt they mount to is loose and causing noise...
    Has anyone seen this before? What crank is this and how do I fix this loose piece?
    Yeti 575
    Rocky Mountain Flatline Pro
    My website/blog with project info
    KulAdventures
    Also my BB just says 12-09 on it... no brand or model #... does that mean anything? What size BB does this bike take?
    Yeti 575
    ups and downs
    Those are a MRP Camber crankset, and it looks like a piece if missing for the pedal insert, possibly a lockring.
    The Flatline uses an 83mm wide BSA threaded bottom bracket.
    You could replace the BB and the cranks with something more durable, the Race Face Chester crank arms and 83mm wide BB as a package. Not a bad deal.
    Race Face Chester Crank Arms | Chain Reaction Cycles
    Attached Thumbnails Attached Thumbnails 2011 Flatline Pro Bottom Bracket and Tool-mrp_camber-cranks.jpg
    KulAdventures
    Quote Originally Posted by rockyuphill View Post
    Thank you so much man. That is really helpful. I have been trying to figure this out for a while now.
    Will that bolt up to the existing chainring and chainstay usually? Or should I order a new chainring also?
    Yeti 575
    ups and downs
    The existing chainring should fit on the Chester, the question would be how worn is your chain and cassette, if they are getting on in years, then it would be likely that going for a new chainring would trigger a need for a new chain and cassette.
    KulAdventures
    Gotcha. Do you see any way to repair the existing crack?
    Sent from my Nexus 5 using Tapatalk
    Yeti 575
    ups and downs
    I'd say those cranks have passed their best before date. If they still made them you might be able to get parts for the pedal insert, but MRP doesn't build them anymore.
    KulAdventures
    Done!
    Got the Race Face Chester crank, chain reaction went up in price so I got it from amazon.
    Did the install, which was pretty easy with the right tools. Did a write up on it to for anyone else tackling this project: https://alex31014.wixsite.com/kuladv...rankset-change
    Finished Project:
    Yeti 575
  1. 2011 RM Flatline Pro IGUS bushing question
    By eshew in forum Rocky Mountain
    Last Post: 08-30-2016, 05:51 AM
  2. Using Bottom Bracket Wrench vs. Bottom Bracket Socket
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2016, 10:36 PM
  3. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  4. 2011 flatline pro msrp.
    By Cygnus X-1 in forum Rocky Mountain
    Last Post: 04-29-2011, 06:03 PM
  5. Bottom Bracket tool and crank tool questions
    By RBikerSD in forum Tooltime
    Last Post: 01-10-2011, 04:36 PM
