Ti bolts for Ritchey 4-Axis stem- Mtbr.com
Results 1 to 11 of 11
    Any know if these exist and if so where I can get some? Or maybe the stem already comes with them and I'm not aware of it? I know the carbon version does so maybe those can be used?
    Mar 2006
    I think it has ti bolts but I will check as I have that stem.
    Quote Originally Posted by elephant
    I checked the Ritchey site and it doesn't meantion Ti bolts for the non carbon 4-Axis but its does for the carbon. That makes me assume that it doesnt come with ti bolts.
    Mar 2006
    racebolts.com and titaniumfastners.com
    Both good suppliers
    Thanks. Wouldn't happen to know the size of the Ritchey bolts?
    Reputation: Atmos's Avatar
    M5x18
    I have fitted Ti bolts in my 4-axis. Some syntace bolts with a tapered head with 16mm of thread, a bit shorter than the original stainless ones, but I think it's enough, I don't use washers with them so that also saves like 1mm of thread. I'm riding already almost 2 years with this stem with ti bolts and it's working perfect!
    If You want Plush, Buy a Couch...
    If you want to go Fast, Buy a 29er
    I can't find tapered Ti M5x18 bolts anywhere online. Am I that dumb?
    Try to order them from Syntace, high quality bolts. Or search on google for titanium bolts or something like that. It shouldn't be such a problem to find any!
    I got the bolts now I need to know if it's ok to use them without washers cause I can't get the stock washers off the stock bolts.
    I am using it for 1,5 years now and haven't used any washers with it because... I couldn't get them off the stock bolts, and the titanium bolts are going to be to short in my case when I use washers.
    I don't believe that it will be any problem!
