Syncros legs in mag21 crown- Mtbr.com
Results 1 to 9 of 9
    Reputation: j333ssa's Avatar
    Ok - picture this. Want to use a Syncros fork on a Toad frame which has a 1" steerer. My Syncros forks have a pressed in 1 1/8th. However I vaguelly remember that it is possible to slot in Syncros legs into the crown of a 1" Mag21 steerer and use them a a rigid fork.
    Am I correct in thinking this? Or am I looking for trouble...
    Big collector of parts always willing to trade. Disk drives, cnc items and rarities.
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Quote Originally Posted by j333ssa
    I think you can actually, though I'm not 100% sure.
    Hollister has some Syncros legs in a Bontrager crown....with IRD steer.
    -eric-
    http://www.rumpfy.com
    Nov 2006
    I was also thinking of pressing 1" diameter chromoly legs into my old Mag 21 crown. There are three considerations.
    One, the tolerances. You had better be very certain that the fit is not so tight as to stress the materials, and not so loose as to possibly come apart.
    Two, that specific crown is designed for suspension. In a rigid assembly, there is no shock to limit the stresses transferred to the crown assembly.
    Three, there is the potential for rotation of the legs under braking forces. These forces are taken care of in the mag 21 by the brace.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    The rockshox crowns are actually stronger than the syncros crowns (which were also aluminium), the problem is the offset of the crowns is less, and the spacing is wider, so you'll need to run a custom spaced front hub along with your brake studs being further apart you'll need to be using cantilever brakes and push the pads out further.
    I don't post to generate business for myself or make like I'm better than sliced bread
    velocipede technician
    Reputation: hollister's Avatar
    d:find the rest of a bontrager fork
    Quote Originally Posted by Rumpfy
    came to me as part of a trade, now i have to
    a;find a frame to use it on
    b:find the rest of a syncros fork
    c:find the rest of an IRD fork
    looking for 20-21" P team
    Illuminati
    Reputation: scant's Avatar
    its been a real long day.. so I've read all of above... is it possible? the wider than normal hub part doesnt sound ideal?
    artistic...
    Reputation: colker1's Avatar
    isn't the rake of RS and other susp forks shorter than rigids? it could sc$$w up the handling.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    The rake is shorter by about a 1/4" but then rockshox crowns were taller than syncros crowns and the rake is measured from the axle center, so the longer the fork the greater the rake will be.
    Nov 2006
    Why not just buy a new rigid fork?
    There are many on the market. You can find old Kona P2s on eBay all the time, dirt cheap.
  1. Repainting a MAG21
    By uphiller in forum Vintage, Retro, Classic
    Last Post: 02-19-2007, 02:15 PM
  2. Getting the most rigidity out of a MAG21
    Last Post: 02-03-2007, 09:03 AM
  3. Good for to replace Mag21?
    By OldBiker in forum Shocks and Suspension
    Last Post: 01-09-2006, 12:17 PM
  4. Which fork to replace Mag21?
    By OldBiker in forum Vintage, Retro, Classic
    Last Post: 01-09-2006, 09:18 AM
  5. It takes legs to ride 44-16...long, beautiful legs....
    By El Beastro in forum Singlespeed
    Last Post: 02-16-2005, 11:06 PM
