Syncros Hardcore Post?- Mtbr.com
    Reputation: OneEyeMan's Avatar
    Aug 2005
    I recently took my Syncros post out and took the seat off to clean the whole thing after years of neglect.
    When I put it all back together, I realized that the head is assymetric.
    One bolt attaches to the clamp higher than the other.
    Does it matter which one is facing forward?
    Anyone have a pic of a properly mounted one?
    Lenny
    Dec 2004
    I took a look at my setup.......
    and the the elevated section is towards the rear . You can also go to bikepro.com and see a pretty clear pic of the proper setup.
    Here is a link to that pic:
    http://www.bikepro.com/products/seatposts/syncros.shtml
    BTW Did you happen to see the used Synchros seatpost auction that ended yesterday?
    OUCH!
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    There's also the fact its not actually a zero-offset design... the posts have a couple mm of setback to them, and head has the rear end a couple mm longer than the front.
    I don't post to generate business for myself or make like I'm better than sliced bread
    Aug 2005
    Thanks Guys
    Lenny
